Pyramat Sound Rocker Gaming Chair  Logo
Question about Pyramat Sound Rocker Gaming Chair
Only my right speaker works and the sub
When i listen to my music the sub works fine and the right speaker but the left speaker no sounds comes out of it and the x rocker doesnt light up either. how can i fix it so it works again?
Posted by Jordan Knol on
Anonymous
    New Friend:
I worked it out. I was having the same problem. you probably have the GREEN EARPHONE JACK plugged into the GREEN INPUT PORT on the side of the xrocker? simply move the GREEN EARPHONE JACK to the BLUE OUTPUT JACK on the xrocker and your sorted :) it was really bugging me so i messed about until i sorted it :)
Posted on Dec 17, 2010
  • Anonymous Nov 26, 2011
    great worked for me after thinking it was the control panel grrrrrrrrr very helpful thank you
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
1helpful
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
I have the sub woffer only would like to use on my comp
No problem....just plug the subwoofer into your Green Port on the computer sound section. The Right and Left channel will merge into a monaural sound and come out of the speaker as if you were listening to music from a radio.
2answers
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
4helpful
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Getting the sound on the right speaker only
Its likely a broken wire. You can take them apart if you are careful and re solder the wire if you have the tools and are ok with doing that. its a little tricky. if you need more help email me. n_raven99(at)hotmail.com
4helpful
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
No sound from right speaker
ADUJST THE SOUND WITH SPEAKER ICON ON THE START BUTTON MENU BAR DOWN
Top Pyramat Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Billius
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
