Question about Aiwa Audio Players & Recorders
I have an Aiwa HS-TX416 that i bought new in packaging but ive found that the tape player portion wont spin at all what might be the reason? Its fresh out of the plastic
Posted by Robert Johnston on
Tom Chichester
    Top Expert:
  • Aiwa Master
  • 61,131 Answers
The tape player portion is defective, though new. Many of the site moderators have had that experience.
Posted on Nov 11, 2020
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Posted on Sep 27, 2007
Anonymous
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
Anonymous
SOURCE: wont take tape
I just posted that I had the same problem with the Elura 100 not taking the cassette, although the compartment will close without a cassette. And I did have the problem with the left wheel rewinding, then the beep occurs.
I was tinkering a bit. I decided to take some video on the SD card, and I let it record for a moment. After that, I went back to trying to get the cassette compartment closed, and it worked! Almost like the camera needed reset.
We'll see if it stays corrected!
Prior to that, I have tried using a can of air, loading a new cassette, etc. And I DEFINITELY did NOT have any condensation!
Hope that works for ya!
Posted on Mar 05, 2009
Anonymous
SOURCE: Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Posted on May 30, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Posted on Dec 18, 2009
Testimonial: "Extreamly fast and accurate responce that was dead -on in finding owners manual for aiwa player."
Aiwa nsx-520 cd player discs not spinning
I have not serviced that model or CD players for a long time. Going from general experience I found a number of reasons. There are a fair number of things that can cause this type of fault. My not be simple. An experienced tech who knows CD players, with the service manual and the proper test tools he should be able to find the failure point.
Some things the tech would check for:
The drive motor.
The servo drive circuit.
If when the disk is inserted, and the disk gets a kick spin and then stops, this could be the laser or the laser circuits are not reading the disk.
It can also be something where inadequate power is getting to the servo drive circuits.
Feb 02, 2017 | Aiwa Audio Players & Recorders
Aiwa Hs-j470 works perfect but for the tape it starts off alright then it starts slowing down and eventually stops give it a small rest then it does the same again.
I'd highly recommend you get those belts changed. They may be stretched a bit, and in time to come, it may cause some damage to your cassette tapes. Get them changed ASAP.
Nov 26, 2014 | Aiwa Audio Players & Recorders
Aiwa TX646 user manual
I suggest search under manufacturer's website, they often keep downloadable pdf versions of the user manuals of all of their products hosted there: http://www.aiwa.com
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 18, 2011 | Aiwa HS-TX686 Personal Cassette Player
Manual for Aiwa TX646
Go to Manualfix.com. If they haven't got it, they'll get it.
How do I get my HS-TX686 to go into continuous auto reverse?
Look in the operating instructions which you would find by searching "Aiwa HS-TX686 manual"
http://www.retrevo.com/support/Aiwa-HS-TX686-manual/id/1077bh447/t/2/
Under "Playback"
Aug 13, 2011 | Aiwa HS-TX686 Personal Cassette Player
NEED A NEW BATTERY
how much is the price of a new batt.?
Jun 13, 2010 | Aiwa AM-F70 Personal MiniDisc Player
Thanks.
Dec 18, 2009 | Cameras
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
22 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
