Question about Watches
This is a band for a OshenWatch. - Watches
Posted by Bruce Casper on
Broken band, how can I get new rubber band? where??
It looks like that may be a custom band, this site has some great bands, http://www.watch-band-center.com/shop-watchstrap.html?gclid=CjgKEAjwoJ-dBRDbjfKN7IzN0FsSJAAP0G_DR8AwTfhcxt7HHIHONLoaf1QZfq7YeqCB6Vt1_oZKV_D_BwE
you'll need to measure how wide your band is where it connects to the watch to ensure you get the correct fit.
Jun 24, 2014 | Ducati Cw0025 Desmo Watch for Men
Skagen replacement band
I am facing the same issue as you. I have a Skagen 311LTRB watch without a band. I purchased the watch without a band, so I don't even know what the original band looks like.
It seems strange to me that Google doesn't even find that model of Skagen watch when you search on the model number. Makes me wonder if the watch is fake or real.
What I did was purchase an 18 mm mesh band and two pins from the following seller on eBay: "BandFever" / "18mm SILVER MESH WATCH BAND,COMES WITH 2 SPRING BARS". It only cost $12.95 with free shipping.
After installing the band, I am now able to wear the watch. And it feels very comfortable with the mesh band. However, it looks a littly dorky because there are overhangs on each side of the watch where the bands attach. I keep wondering what the watch appeared like when it was new with its original band.
Aug 27, 2013 | Watches
Have a Titanium Skagen watch #311LTRB and would like a replacement band. Can you assist?
Wish I could paste an image of the watch, but that doesn't seem to be allowed.
I want to buy wristband for my nautica n 135 30
This is a proprietary fit band. Only the manufacturer carries the band. You will want to contact Nautica's watch department customer service directly at:
[email protected]
Nautica watches are produced by Timex, so this is the correct email.
Specify the model number, serial number, band number (if you see one on the reverse) and request price and availability for the band.
If the band is not available, they may be willing to offer you a new watch as replacement.
Feb 04, 2011 | Nautica Resin Round Chronograph #N14537G...
I have a calumet watch, and the band is getting dirty. Is there a way to clean the band?
Polyurethane Band
Polyurethane Bands, which are made of soft plastic, may turn hard after 2-3 year's use. Colour fading can also be seen.
If bands are kept wet and in highly humid locations or are exposed to sunlight for a long time, the deterioration of the bands may be accelerated in a relatively short period and some cracks may appear on the band surface. (This is called 'hydrolytic cleavage of polyurethane')
Kindly pay attention to the condition of polyurethane bands, which are often worn in such occasions as marine sports/outdoor activities
  • We recommend immediate exchange when your polyurethane band loses elasticity or develops cracks.
  • Semi-transparent/white/fair coloured polyurethane band may turn a different colour due to light/stain ( or sometimes may absorb colours from other materials). In addition, polyurethane bands have many small holes on the surface, which easily catch and hold stains/other different colour material. Thus it is rather tough to entirely clean polyurethane bands. Kindly replace current polyurethane band with a new one when you find extreme discolouration.
  • There exist some sorts of stains (like oil/cosmetics), which cannot be removed off. Smoking cigarette/long time use may turn the colour yellowish.
CAUTION!
Do not use solvent/chemicals (benzene/thinner/breach) for band/bracelet cleaning!
Aug 24, 2010 | Alessi Watches
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Casio G-Shock GW-300 replacement bands
    I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
    This cost disturbs me.
    Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Anne Klein 10/5875 Y121E
    You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
    You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
    Do not forget to rate, please.
    Feb 27, 2009 | Anne Klein 108293SVBK Watch
    Watches Logo
    16 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
