The timer has 3 prongs holes. Do you think I might need an adapter for my dehydrator which only has 2 prongs?
I have no experience with dehydrators but I know of nothing that makes them electrically different to any other appliance. Clearly as it only has two prongs it is a double insulated device and doesn't need a ground connection and this is common with various other devices that might need controlling with a timer.
As long as you connect your appliance to the power pin receptacles of the timeswitch and ignore the ground, it should work if the timer has been set per instructions - as it is basically an electric clock, if it is working the timer dial should move indicating the current time. The connection to the timer can be tested by moving the override switch found on the lower right of the timer, when your dehydrator should be permanently switched on.
SOURCE: Need owners manual for Nesco Gardenmaster Food Dehydrator FD-1000
Here is the User manual you require mate :
http://www.nesco.com/files/pdf/food_dehydrator.pdf
Lemme know if this resolves your query :-)
SOURCE: Food Dehydrator
I have scanned the pages from my copy to this photobucket album :
http://photobucket.com/DurabrandDehydratorKN-128E_Manual
SOURCE: Looking for instructions a food dehydrator...it's
Here is the link to down load the manual in Adobe PDF format:
SOURCE: I have a dehydrator and do not have instruction of
I need a instruction manuel for a Nesco dehydrator.
SOURCE: I am looking for instructions
I have an original copy of this maunual for my unit. I'd be happy to copy and send to you. please email me at
[email protected] if you are still in need of the operating guide w/recipes.
Thanks,
Susan Sheppard
