Question about Freezers
Hi my norfrost chest freezers orange light switch has popped off. Its not broken so does anyone know how i put it back on thank you. Colleen
Posted by Colleen Stoker on
Simon Atkinson
  • 1,828 Answers
Could you comment below with more detailed photos of the back of the orange switch and any other bits with it. If the switch isn't broken It might just 'click' back in. I don't know without better images.
Posted on Aug 25, 2020
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
Anonymous
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
Anonymous
  • 1185 Answers
SOURCE: an orange light is on next to the green light on
Normally orange signifys that the machine has been switched into fast freeze , check your controls
Posted on Sep 04, 2009
Anonymous
  • 4 Answers
SOURCE: nova scotia chest freezer - does orange light
I have a nova scotia chest freezer on the indecater it is 0 to 5 which is the coldest number 0 or 5
thank you
Posted on Dec 12, 2009
geoff hunter
  • 4793 Answers
SOURCE: My Norfrost chest freezer has stopped working will
which means that it is operating manualy...could be the thermostat needs replacing...
Posted on Mar 03, 2010
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Norfrost c6aew chest freezer compressor wiring
What is the make and model of this freezer?
Mar 14, 2013 | Freezers
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Dec 13, 2011 | Freezers
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
My Norfrost chest freezer has stopped working will only freeze when the turbo button is switched on. Please help
Feb 28, 2010 | Freezers
I have a Norfrost 100ltr chest freezer that is defrosting on normal setting but the fast freeze and compressor run when switched on. Any suggestions as to the problem
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Freezers
Freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Oct 19, 2008 | Freezers
Freezers Logo
14 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
