Question about Watches
I have a Michael Anthony ladies watch. Do you know what battery it uses.
Posted by Joe D on
I have a mk 5055 Michael Kors watch and I don't have the proper tools with me I only have a flat bed screw driver and I need to change the battery
Read the solutions given below when you want to change the battery right from your place.
step 1: Remove the back panel of your watch.
Step 2: Locate the battery in the holder and identify its type.
Step 3: Use the user manual for reference before installation.
Step 4: Place the watch and the back panel in a plastic bag to avoid contamination during replacement.
Step 5: Remove the old battery from the watch.
Step 6: Have in hand a newly purchased battery and install it.
Step 7: Check whether the watch works after installing.
Step 8: Replace the back panel on your watch.
Step 9: Set your time and wear it.
To Get Instant Support Call our Toll-Free 1-866-293-9220
Sep 18, 2018 | Michael Kors Watches
Does michael kors watch 5498 use battery?
Yes, MK5498 uses battery.
Regards.
TicTacArea.com is Official Michael Kors dealer
Michael Kors Watches MK
Aug 18, 2014 | Watches
Where do I find the serial no on Michael Kors watch MK 5235?
The watch case back under the name and above the words water resistant.
Apr 16, 2013 | Michael Kors MK5235 Chronograph Pearl...
Mk 5473 watch is loosing time
Okay, so I'd the watch dial says automatic or manual wind you should be able to wind the watch to get it to start working. If the second hand is sweeping buy the minute and hour or just minute hand does not go around properly there are different issues. One. It could be the pinion that is loose, (major repair) two, the watch needs an overhaul meaning cleaned and re oiled(less likely). If only minute hand is giving trouble, its loose(the 2nd hand) or the pinion is loose.
Mar 26, 2013 | Michael Kors MK5473 Ladies Logo Watch
Changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
Ladies quartz watch stem winder knob lost lost how to remove from another to fix it?
mcdevito75 here, Best bet, look for a small watch repair shop in your area for another knob. As long as the stem is in place you just need the winding knob.
May 23, 2011 | Michael Kors MK5166womenGold Tone...
Watches Logo
20 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
