How can I use HDMI for my computer - Computers & Internet
Posted by Sanat Altin on
  • Larry Ng
    Larry Ng Aug 25, 2020
    no computers stated, at all nor OS.
    now what you want to do.?
    HMDI is communications interfact that allows connections of many things HDMI ready.
    like Monitors. TVs and more,
    what's up doc. ? we can't guess that.
  • Larry Ng
    like TV, DVD/BR players, decoders, gaming consoles, cameras, and more. Receivers, sound systems, settopboxes (TV) and projectors, monitors.
    tell what you have there first, your equipment all. or tell one goal.
    Tell what you want to connect.
    short answer yes, if it has port.HDMI
    yes,
    if not we can add one if not laptop.
Aron
  • 1,570 Answers
Connect one end of the HDMI cable into an available HDMI port on your TV. Take a note of the HDMI inputs numbers it's being connected to. Plug the other end of the cable into your computers HDMI out port, or into the appropriate adapter for your computer. If you are using an adapter, connect that adapter to your computer
Posted on Aug 25, 2020
How do i get a movie to play from computer to the tv with hdmi
If your TV has an HDMI input - connect up the computer to the TV with an HDMI cable.
Select HDMI on the TV inputs.
Play the DVD on the computer, should appear on TV is Input is set. Sound may be a fiddle ~ check you PC sound settings if there is none.
The computer will usually show a blank screen when the HDMI is going elsewhere,
Good luck
Apr 20, 2014 | Vizio E421vl 42 Inch Class Lcd Hdtv
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
Acer X233H Input source
Hi, maybe there's no video coming out from CPU HDMI port , and that's why monitor returns to DVI input, to test monitor HDMI input you can use another HDMI video source, as a DVD or Bluray player.
Jan 01, 2018 | Acer X233H 23" Monitor
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Nov 21, 2009 | LG 42PC1R 42 in. Plasma HDTV
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Computers & Internet Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
