Question about Oreck Vacuums
I am looking for a wiring diagram for an Oreck model XL 9800 upright vacuum cleaner.
Posted by Dave Anders on
Tom Chichester
    Top Expert:
  • Oreck Master
  • 60,283 Answers
Contact Oreck directly to request the diagram.
Posted on Nov 12, 2020
5 Related Answers
Anonymous
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
Anonymous
  • 5 Answers
SOURCE: My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Posted on Oct 15, 2008
Anonymous
  • 4 Answers
SOURCE: formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Posted on Apr 24, 2009
WonderTech
WonderTech
  • 268 Answers
SOURCE: While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
Posted on Aug 20, 2009
How do I access a wiring diagram for handle switch assembly on an Oreck XL upright vacuum?
Go to www.hescoinc.com. Click on schematics under information on the left side of the page, then click on Oreck and find your model. Hopefully that has enough detail for you. You can order parts from them too at prices lower than most other distributors.
Feb 02, 2015 | Oreck XL Ultra Bagged Upright Vacuum
Install instructions orick power cord upright
You can find the assembly and wiring diagrams on this site to help you. Please check the correct model number as you have not provided this.
Oreck Upright Vacuum Parts
Aug 30, 2014 | Oreck Orek Upright Vacuum Cleaner -...
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I have to replace a motor on an xl classic. The bad motor is out and i do not know exactly where the wires connect on the new one. I need a wiring diagram.
Hi, it's Jeremy from Crucial Vacuum.
Below you will find a link for many different models of the Oreck XL Classic Bagged Upright Vacuum. I hope you find the link useful.
http://www.oreck.com/PUG/76054-01-REV-A-U2251-CLASSIC.pdf
If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 22, 2014 | Oreck XL® Classic Bagged Upright Vacuum
Oreck xl 21 fan housing has new design. willit stillfit my older vac
It should. You can call Oreck and talk with them and give them the serial number off your vacuum and they can look it up and tell you for sure if it will fit or not.
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL upright
I just sent you tge diagran to your email, hope this will help.
Oct 18, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
23 people viewed this question
Top Oreck Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
