Ican't tilt this new monitor. does it tilt? It's an onn 24 monitor
Posted by Jack Hagen on
  • Larry Ng
    Larry Ng Oct 21, 2020
    many dont; cheap.
    it can be upgraded, if 100x100mm rear mount .
    walfart ONN junk wow.
    tilt not up and down tilt is more fancy.
    i guess you have this?
    Product Title
    ONN 24" 1920x1080 VGA HDMI 60hz 14ms LED Slim Design Monitor
    ONA24HB19T01 ?????????????????
    you can see it has no tilt i the ad.
    it states
    With a no screw clean back and a simple T-shape stand,
    I guess no screw means no ISO 100x100 plate to use custom nice base stand like I have.
    mine goes up down swing and tilt.
    so that spec above is a lie. (onn) lies
    the first review said
    ONA24HB19T01
    view said at WM.
    THe stand can be tilted. It is not obvious and I had to hunt for it but, once you find it, it is easy.
    for $99 that is all you get.
    let me guess no manual and we already know ONN has no website help, and why id never buy this junk from them.
    go Viewsonic, !
    ONN is bottom fishing, for a fact. watch out for flounders. or worse. LOL
  • Larry Ng
    just so you know, all these fit my monitors
    https://www.amazon.com/monitor-base-stan...
    some do ISO standard 50/75/100mm mounts
    good ones do.
Joseph Wright
  • Computers & ... Master
  • 1,706 Answers
If it's Model: 100012590, then it appears there's no adjustment.
Posted on Oct 21, 2020
  • Anonymous Oct 21, 2020
    you can read the backside of his monitor
    wow,
    but what if its a ONA24HB19T01
    sold now. non stated, so who knows
    if it as a iso mount bases are easy to buy,
    childs play and 4 screws.
Tilt trim motor runs by itself
Faulty solenoid,trim switch or shorted wires in control box
Jan 16, 2014 | Boating
Stand monitor
The monitor should be able to move up and down and tilt from its stand. You can try this by grabbing the sides of the monitor and rotating it inward or outward. It should not take much effort to get it to tilt. If it doesn't move with minimal effort then it may not be able to tilt.
Oct 14, 2013 | Acer Aspire 5600U all-in-one desktop
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
Opening samsung t240hd monitor
http://userguideme.org/t240hd-manual-download.html
Dec 09, 2011 | Samsung SyncMaster T240HD 24" TFT LCD...
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
How do I tilt my screen?
just hold the bottom of the support in your left hand and apply force on the top of the monitor or lcd and the force should be in the downward direction. now you are through.
Dec 29, 2009 | Acer AL1916W 19" LCD Monitor
Cracked Dell 2405FPW 24" LCD flat panel
The screen needss replacing. Hubby won't be happy!
Jun 19, 2009 | IBM ThinkPad R40 2722 Notebook
Monitor Pivot won't turn for the monitor to tilt
If it is crt monitor rotate and tilt up or down. If it is Lcd just push to move front or back.There is nothing to be loosen.
May 04, 2009 | Computers & Internet
Tilt new monitor???
mcdevito75 here, I also have an Acer and it Doesn't tilt, that doesn't mean yours won"t, try to hold the monitor by the top and simply try to tilit it while makeing sure the base stays flat on the desk, (table) don"t force anything. Also look for any kind of screw, or handle connected to the base (bottom) or near bottom of back of monitor. Hope this helps. Oh! also check the manual that came with the monitor, mine has no mention of tilt. Sorry.
Jan 18, 2009 | Acer X191WSD Monitor
Pluged in a new one and it does not seem to be cooling off
did you tilt it prior to plugging it in you are supposed to wait 12 to 24 hours to plug them in if theyve been tilted at any time during transport.
Dec 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
Computers & Internet Logo
21 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
