Question about Tappan 30IN ELEC IGNa Oven
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Mar 27, 2018 | Tappan Ovens
Jan 30, 2017 | Kenmore Ovens
Hello devon, thank you for your post!
I understand that you need the location of a reset button on your Tappan range. Typically, there is not a reset button for your range. A reset can be done by disconnecting power from your appliance for ten minutes. I hope this information is helpful. -Matt
Oct 25, 2014 | Tappan Ovens
Aug 10, 2014 | Tappan Ovens
Jul 15, 2014 | Tappan Ovens
Aug 22, 2010 | Frigidaire Ovens
Jan 19, 2010 | Ovens
Jan 10, 2010 | Tappan Ovens
Sep 17, 2009 | Ovens
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
4,026 people viewed this question
hello i keep getting the f10 code on my oven. I checked the sensor probe and replaced it with a new one and it still occurs. what else can be the problem? It always burns my food.....
