a joggers wrist watch device for distance and other things, heart rate etc. it is NO COMPUTER at all. sports Watch.
how to fix. you asking for a service manual, that it? NONE. the device is a toy, replace it. the device repairs exceed new costs, econ 101 answer. nobody sells parts for toys.
ask them it is there product and is not a computers.a joggers wrist watch device for distance and other things, heart rate etc.
econ 101 answer.
ask them. not use we do not sell this fix this or sell parts or manuals nor parts lists that do not exists.
https://us.amazfit.com/pages/contact-us
You can't post conmments that contain an email address.
Hi!
To solve it you need to pair your wacth to your phone. and it will automatic fix your timezone as is set up on your phone.
Go to your phone > select bluetooth > select your watch name.
with the playstation off put your finger in the on/off switch you will heard one bip ( this is when the playstation turns on) keep your finger there in the on/off switch ultil you hear a second bip now remove your finger and this second bip is when the ps3 video settings are reset it should work again on rca just way a few seconds and your will see the screen again on rca
tre bip lunghi potrebbe essere un problema della tastiera. Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco. * Un bip = tutto funziona normalmente. * Due bip = errore POST/CMOS. * Un bip lungo ed uno breve = problema con la scheda madre. * Un bip lungo e due brevi = problema video. * Un bip lungo e tre brevi = problema video. * Tre bip lunghi = errore tastiera. * Lunghi bip ripetuti = errore di memoria. * Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre. * Continui alti e bassi bip = surriscaldamento CPU. guarda anche questo sito http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
1st step you can check how many bips you hear, if continous bips , checks your vga by change with other if you sure that your ram and hd is ok, 2st if problem isn't solved ,remove all your card and clean all contact part all card with liquid cleaner, pci slot vga slot ram slot and processor socket after that you can try to assemble your card again , ok good try
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Find it in "my computer", right click it and select format. Choose the FAT32 option and hit OK.
Once its done, restart your computer and plug in your pod. Start itunes and it should automatically reinstall the ipod firmware.
econ 101 answer.
