Question about Electrical Supplies
The GFCI connected to Intelliseat ISB-200 disconnects when the plug is inserted when connected to power bypassing the gfci the seat works I have a safety concern about e GFCI
Posted by thenrim ri on
Carl Rock
  • Electrical S... Master
  • 2,624 Answers
Is this a new bidet installation, USA? What year was home built and/ or remodeled?
It's probably safe but It would not be wise to use the unit without GFCI protection.
Please describe the installation. Is it plugged into a bathroom circuit with a GFCI breaker in the house panel or is there a GFCI receptacle protecting multiple outlets in the bathroom.
The typical cause for GFCI nuisance trips is an improper connection of protective equipment ground and neutral (grounded conductor) somewhere downstream of the GFCI protection device. IOTWs, a white neutral wire is touching bare ground wire or metal box.
You might try plugging the bidet into a long 3 wire extension cord so you can try a different GFCI outlet... in the kitchen or dining room. If it works at different GFCI circuits then likely it's not the unit but rather the bathroom wiring.
Comment below for further assistance.
Posted on Aug 20, 2020
Motion light after a gfci plug trips,
power off disconnect motion light power on reset gfci. if it trips he problem is between breaker and rec.., or replace gfci with another one.is box dry even a small amount of water will cause it to trip. do not float grounds or neutrals, ensure that the black power wire is on the black terminal on line side.
Jul 21, 2018 | Electrical Supplies
Tip
Wiring a GFIC alternative.
When wiring a GFCI (Ground Fault Interrupter Circuit) receptacle you would normally connect the wire coming from the service panel or the hot wire to the LINE connection at the GFCI and then connect the other receptacles you wish to protect to the LOAD side on the GFCI. But let's say you have installed a GFCI in a garage circuit and want to run a wire to the garage door opener from that circuit without the garage door opener receptacle being protected by the GFCI but still want all other receptacles protected. Reason being that the garage door opener will trip the GFCI more often than not. You may also want to have a receptacle for a freezer in the garage. You do not want that freezer protected by the GFCI circuit as it may trip without your knowledge and cause all the food to spoil. Warning: Only install a single plug receptacle for the freezer and not a double plug receptacle. That way only one thing, the freezer, can be plugged into this receptacle as it is not GFCI protected. The way to avoid the breaker tripping is to connect the garage door opener & freezer receptacle to the LINE side of the GFCI. This way it is not protected by the GFCI and there is no danger of that receptacle loosing power due to a tripped breaker on the GFCI. When the GFCI trips power will still be available at any receptacle connected on the line side. On any GFCI you can connect two sets of wires to the LINE side. If you have more than two you will have to connect those together under a wire nut and then use a jumper wire to connect to the LINE on the GFCI. Look at the photo and you will see the 2 sets of holes to connect at the LINE side (Bottom) on the back of the GFCI receptacle. There are also 2 sets of holes to connect on the LOAD side (Upper). Of course you would use a wire nut and jumper to connect all the ground wires.8dd2149.png
on Dec 13, 2009 | Electrical Supplies
The seat is cracked and doesn't heat anymore, is there anything I can try before buying a new one?
if the seat is cracked then the element is probably broken at the crack site
check for circuit continuity of the element or buy a new seat
can't be too hygienic or comfortable sitting on a cracked seat
Jan 20, 2016 | AMDM Intelliseat - The Ultimate Bidet...
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
Why can't we get the nozzle to move?
If you need a replacement part that includes a functional nozzle, you can purchase it here http://www.ebay.com/itm/Intelliseat-AMDM-ISB-200-body-Replacement-/222019823660?hash=item33b169a82c:g:v8QAAOSwzgRWvLSS
Aug 27, 2013 | AMDM Intelliseat - The Ultimate Bidet...
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Hi, I recently had problems with my gfci outlets. I have 4 outlets connected to a gfci circuit and I cant get the other outlets to work if nothing is plugged to that one outlet at the end. The gfci outlet...
that is truly a strange problem, has there been any rewiring going on? almost seems that it wired in a series instead of a paralell circuit and the end one completes the circuit when something is plugged in. i am not sure how to tell to fix this other than to go thru the whole circuit.
at the gfci the line side, or the hot wires supplying it should be hooked up to the line side of the gfci. the wires feeding the rest of ur outlets should be connected to the load side of the gfci.
then at each outlet the hot wires both line and load should be hooked up to the brass or gold looking screws and the neutrals should be hooked up to the silver screws. this way u should have power on all the outlets.
Aug 11, 2009 | Leviton 8299 Combination Switch / Smart...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Hobart 20 QT. mixer (HL 200) will not operate on a GFCI receptacle.
you need to replace the gfci,the older gfci's interpret these frequencies as a shock hazard and shut off power to the circuit.you can buy @hobart, part#913053, that should solve the trip problem. dont forget to vote thanks monomoy
Apr 05, 2008 | Food Mixers
Electrical Supplies Logo
19 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
