Question about Frigidaire Washing Machines
Frigidaire Model FPEF3081KFA has error code of F-10. Do I need to change the control board?
Posted by Janet Perez on
5 Related Answers
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Frigidaire Front load washer
hmmm...are all the cables re installed in same fashion as before?
Posted on Apr 30, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: hi there, ive got an frigidaire washer atf6000es frnt load
yea board or latch)latch usually shows fault. the board is located left rear of unit, first ck for loose wire connection leading to it.
Posted on Oct 31, 2008
pierre1811
Perry Putnam
  • 144 Answers
SOURCE: E6 error code displayed on Kenwood kdw243a dishwasher
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Posted on Jan 19, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2009
Anonymous
  • 212 Answers
SOURCE: Code F43 on frigidaire front load washer.
motor control possibly bad
Posted on Jun 20, 2009
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
What does area Error code E-05 mean on a Frigidaire front load dryer model # AEQ6000ES2
model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
Dec 26, 2015 | Frigidaire Dryers
What is error code f69 on a frigidaire electric range
Hello. You have a serious problem--that error code means L1 or L2(the 120v supply wires) may be shorted with the neutral on the incoming power supply. TURN OFF THE POWER!! Check the wiring at the terminal block. The neutral is the center post. L1 is usually black and L2 is usually red. The F68 and/or F69 error means high voltage or the above-mentioned condition. Once you have verified there is no incorrect polarity or voltage condition, then the main oven control board must be replaced. The part number you might need is 316562011. I hope I helped you!
Sep 20, 2015 | Frigidaire Kitchen Ranges
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Code 5y ce
Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Dec 18, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
How do you make an F-10 error stop if the Clear/Off Key does not respond?
f10 error code means there is a problem with your temp probe.if you change the temp probe and this does not fix the unit then you electronic control board needs to be replaced
Jan 26, 2010 | Frigidaire FGB24S5A Gas Single Oven
Why does my Frigidaire electric slide in range keep beeping and showing an error code F-10. Model # CPGS389EC
F 10 error code is not listed on my error code sheet and in my experiance error codes not listed are internal controlboard error codes and the control board should be replaced.
Jan 07, 2010 | Kitchen Ranges
Washing Machines Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
