Question about Bose Audio Players & Recorders
Where can I buy Bose Companion 5 Bass circuit boards?
Posted by Alejandro Gonzlez on
5 Related Answers
johntolfa
SOURCE: Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Posted on May 17, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: where can i buy a
Check ebay or ask Bose:
Bose Companion 3 Handy Control Pod $32.50 - eBay
Bose Companion 3 Control Pod $33.99 - eBay
Posted on May 01, 2009
Anonymous
  • 9 Answers
SOURCE: can i connect my bose companion 5 to a lcd t.v
yes use an auxilliary
Posted on Jun 17, 2009
Anonymous
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Posted on Apr 10, 2010
Testimonial: "Thanks for the insight! I noticed that when I unplug the power cord, the amplifier makes a loud crackling noise. I'll investigate."
Bose repair
Does not seem very complex. I think it is because of the broken fuse. Simply Open the back part of Bose companion 5. The Circuit board attached to the back part is basically for the Audio output socket, Control pod Connector and Power supply connector. on the Left hand side of the board you will find a fuse soldered with the board. most probably that fuse is broken. replace the fuse if broken or just connect both end of the fuse with thin wire (temporary) to check. Hope it helps.
I am outta home or else i could have added an image for you. maybe tomorrow.
Thanks
Jun 23, 2014 | Bose Companion 5 Multimedia Speaker System...
Where can i get bose power supply distribution circuit?
I have a companion 5 . I bought it in UK hence 220 volt out needed . I move to Venezuela where Volt out let is 120 volt . It doesnot work due less power available . what can I do
Dec 26, 2012 | Bose Companion 5 Multimedia Speaker System...
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Producing Unstable Sound
The intensive bass is making the speaker shake very much and that could have caused a short that changes the volume after a while when the speaker has been shaking for a period of time. You could try lowering the bass or volume to see if it makes a change in how long it takes to make the volume change.
Oct 18, 2008 | Audio Players & Recorders
19 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
