Question about Jensen Radio Communications
Where can I get a PDF user manual for my Jensen Model JCD-DD6BT car radio? Or even the basic features to allow me to get the most out of it? Thanks in advance.
Posted by Choonara on
Tom Chichester
    Top Expert:
  • Jensen Master
  • 60,372 Answers
Contact Jensen to inquire.
Posted on Nov 14, 2020
5 Related Answers
Anonymous
SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
Posted on Sep 18, 2007
Anonymous
  • 236 Answers
SOURCE: changing time on a Jensen CD315x car cd player
Hi Kristine,
Here ya go:
Press DISP for 3 seconds until colon flashes, then release.
Press << to change hours, press >> to change minutes..
And clock is set!
Posted on Mar 28, 2008
Anonymous
  • 477 Answers
SOURCE: user manual for canon ixus 860
Hope this helps
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=15655
Posted on Apr 25, 2008
Anonymous
  • 7 Answers
SOURCE: Wharfedale user manual
i have copied manual to pdf, happy to email it to you
Posted on Dec 29, 2008
award462
Anthony Ward
  • 397 Answers
SOURCE: I need a blueaction bluetooth user manual for
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Posted on May 06, 2010
Hi, I have a Jensen JCD 233u car radio, I've tried to connect the power on it but I fail, these only four power wires behind, ground, auto antena, memory and 12 volt positive wire, Please help how can I...
Ground - negative
12v positive - switchable positive (for example, on when ignition is on, usually connected to accessory side on ignition switch)
auto ant - connected to your electric antenna or to turn on external amplifier.
Memory - connected to always on positive (to keep all your stereo presets )
May 02, 2018 | Jensen Car Audio & Video
Program my 2 way radios k7gfv700
You will need to program the MR350 radio to have the frequency and code match. This radio has several other feature such as QT filtering and call alert. For basic operation turn off any special features. Here is a link to the user guide where you will find instructions: http://content.giantintl.com/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Oct 12, 2014 | Radio Communications
I cant sync my two motorola k7gfv700 walkie talkies
May 08, 2012 | Motorola Walkie Talkie 2-Way Radio
My grandkids played with the talkies and now I can't get them to talk back and forth. I can't find my manual and have no ideas what the buttons are or what is going on. my model number is...
Check the programming of your frequency, interference eliminator code and Qt filter (if any). Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/FV700%20FINAL%20-%20%20All%20Rights%20Reserved%20and%20call%20center%20email%2004-24-07.pdf
For basic operation turn off any special features, and set the code to zero (off) and the Qt filter (if any) to zero (off). This would allow you to test the radios in a simple mode, with just the frequency number needing to match between the two radios.
Best regards.
Aug 29, 2011 | Motorola Walkie Talkie 2-Way Radio
Good evening: We purchased Morotorola MR350R radios a few months ago. Just now getting around to using them. We took the User Manual and set both radios the same. You can push to talk on either radio...
Try going back to a basic operation, shutting off any special features. Unlock your front buttons, if locked, and proceed with setting your frequency to 1, your code to zero (off), call tones to zero (off), etc. Then see if the two radios communicate. If not, you may have one bad radio, or a battery issue.
For the reference of others reading this here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Aug 21, 2011 | Motorola Radio Communications
I have a pair of talkabouts fv700's they will receive but I cannot transmit
Best regards.
Oct 17, 2010 | Motorola Walkie Talkie 2-Way Radio
I bought a Jensen clock radio 1250 second hand - it has no am aerial and no manual - can I get an aerial and a manual thru you, please? ...Liz
I can't locate any Jensen clock radio with the model number 1250 -- could it be the Jensen JiMS-125? If so, it has no external AM antenna, but here's a link where you can download and print the operating manual:
http://www.spectraintl.com/jn/pdf/JiMS-125%20English%20UM%20%28USA%29.pdf
Bill B
Mar 24, 2010 | Audio Players & Recorders
Radio Communications Logo
18 people viewed this question
Top Jensen Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Jensen Radio Communication Expert? Answer questions, earn points and help others
