Question about Sony Audio Players & Recorders
Model MHC vx33. Why is it in protect mode?
I disconnected speakers but that did not work.
Posted by manu matharu on
Tom Chichester
    Top Expert:
  • Sony Master
  • 60,274 Answers
It is in protect mode because of component level failure or cold solder connections.
Posted on Nov 15, 2020
5 Related Answers
Zlobomir
Zlobomir
  • 225 Answers
SOURCE: my sony mini hi fi system.model mhc-nx1.reads ;
Lucky guess: you have an auto-fuse somewhere on the back of the unit.
Posted on Nov 08, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Posted on Sep 29, 2008
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
ABRsvcs
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
Anonymous
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID [email protected]
any sony music system problem
Posted on Nov 07, 2009
My Sony mhc gx355 stereo red light flashes buthe it's not powering on
Try disconnecting all the speakers, the red light may indicate the player is in "Protection" mode. That mode is triggered by a short in the speaker voice coil or the wiring to them.
Feb 25, 2017 | Sony Audio Players & Recorders
Sony mini hi-fi system MHCVX33 Audio-VCD, i want to change (Track CD to DVD Mp3 format)
Not possible. DVD to MP3 is a transitional change using a software program like that from Wondershare.
Feb 02, 2015 | Sony Audio Players & Recorders
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD is doing what?
I cant get "PROTECT" off my Sony MHC-EC909iP Mini Hi-Fi System.
Disconnect the speaker wires from the unit. If it still says protect when you turn it on, then the amp ic has been shorted and needs to be replaced.
Feb 12, 2013 | Audio Players & Recorders
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
What is "Press Power Protect"?
Hi Lois,
Stereo sytems have a protection circuit that alerts you by displaying "protect" when there is a electrical short circuit detected in the system, the most common short happens in a speaker, try disconnectig the speaker wires of both speakers(all speakers) at the back of the system, then play the CD or cassette player(although you will not hear anything with the speakers disconnected) and see if the unit goes into "protect" mode if the problem is still present then you have an internal short circuit and the system will need to be sent in for service or replaced(depending on age,repair costs). I would not recommend investing more than $80 into repairs. Now, if the unit does not go into "protect mode" then one of the speakers or speaker wires is shorted,be sure you check the conndition of the speaker wires before you replace the speakers, then you can replace the speakers(in a pair) and you should be back up and listening! Good luck and Merry Christmas !
Dec 03, 2009 | Sony MHC-NX1 Shelf System
Sony Mhc GS100 want power up
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
Push protect problem/ sony MHC-VX33
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
Defective sony vcd Model MHC-VX33
If it havent been use for a long time try dusting it and cleaning it first, sometimes dirt gets stuck on vital places which makes it go crazy. Hope this works. Please dont forget your rating for me as well...We take time in answering problems. Thanks
Jan 25, 2008 | Audio Players & Recorders
Sony MHC-GX9900 Shelf System
i have the same problem with the blinking light this problem is due alot to over heating be careful your fan is not burned up or is not being blocked it is a protect mode activation to prevent overheating
Jul 04, 2007 | Sony MHC-GX9900 Shelf System
19 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
