Dryers Logo
Question about Dyson Dryers
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
Posted by MrRunon on
Simon Atkinson
  • Dyson Master
  • 3,175 Answers
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems.
If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
Posted on Aug 17, 2020
4 Related Answers
Jesse Hassan
  • 54 Answers
SOURCE: Power outage due to power
You have a power supply issue on the main board of your set. This is not an easy fix for a home owner, Your best bet is to call a service shop and get a price quote. Tearing into tv's is very dangerous! High voltage is present even when unplugged! Good luck!
Posted on Aug 19, 2008
Anonymous
  • 1768 Answers
SOURCE: Due to surge in power,
1. usually when a power surge has occurred and a electric appliance is the victim o f that surge the first thing in the power supply circuit to go is the rectifier diodes or rectifier array and the surrounding filter capacitors. this array regulates the AC coming into the set as a full wave signal.
2. It is wise to refer to a schematic when repairing a rear projection TV. Some components are static sensitive.
3. checking all the component at the input of the start up circuit is first and foremost.
Posted on Jul 07, 2011
Anonymous
  • 24 Answers
SOURCE: Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Posted on Sep 06, 2011
dissonantcry
dissonantcry
  • 71 Answers
SOURCE: tv won't turn on due to power surge
It's technically possible, but depends on the damage.
Posted on Jul 01, 2012
2answers
What does e8 mean on the display?
http://www.dyson.co.uk/support/am04/am04-irsbl/my-machine-is-not-working/e1-e5-e6-am04
Why does cove e8 shows
Hi there, it's Jack at Dyson.
If your Dyson Hot + Cool heater is displaying an E8 error code, the best course of action would be to contact us directly for further help. We'd appreciate the opportunity to take some further details about your particular machine and how it's being used. Additionally, if a replacement is needed, we can confirm if this is covered under your 2-year Dyson warranty.
You can reach us by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you and providing further assistance.
Dyson AM04 e3 error message
I'm sorry to hear your AM04 is displaying an error code, but we're keen to help you check your machine is working as well as it should be.
When you have your AM04 to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We can take you through some simple troubleshooting checks, and if a repair or replacement is needed, we can confirm if this is covered under our 2-year warranty.
We'll look forward to speaking with you.
Dyson hot cool AM04 fan. I purchased this on eBay with a warranty and was told by the seller after receiving it a converter is required to use it in Australia. However it turns out using the converter...
Hi Seaye, it's Jack at Dyson.
Dyson appliances are engineered for use within the countries they're sold in, and we do strongly advise against importing a Dyson machine from one country for use in another. As you've mentioned, this can void the warranty, and a machine made for use in another country will not meet local legislation in Australia. Additionally, we're unable to guarantee that we'd have facilities available locally to support the machine with spares or servicing in the event of a breakdown.
The Dyson Australia Support team will be best placed to help further with your enquiry, and I would encourage you to call them directly on 1800 239 766, or to email them at [email protected]
Someone will be in touch as soon as possible to discuss your concerns.
Cool function stopped after 3 rd time use. error 4 displayed
If your AM04 is displaying an error code 4, you should be able to resolve this by turning off the machine and unplugging it from the power supply for 30 seconds.
You should then find that the issue is resolved when you test the machine. If you're still having difficulties after trying this, please get in touch with us directly for some further assistance. If a repair or replacement is needed, we can confirm if this is covered under your machine's 2-year warranty.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
AM04 ONCE TERMOSTAT TEMP IS REACHED, UNIT POWER SHUTS OFF AND HAS TO BE MANUALLY RESTARTED
Hi Jeanette, it's Jack at Dyson.
It's normal for the fan to revert to monitoring mode once the target temperature you've selected (shown on the LED display on the base) has been reached. But the machine should automatically turn itself back on again once the temperature drops below the target.
If you feel it's not doing this as rapidly as it should be, or if it seems to be shutting itself off completely, we'd encourage you to get in touch. If a repair or replacement is needed we can confirm if this is covered under your machine's 2-year guarantee.
You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Heater won't work
AM04 has an intelligent thermostat which you can set to the degree. The machine will then monitor the room temperature and cycle on and off as needed to maintain the temperature you've chosen. If the heater doesn't seem to be running, it may be because the temperature you've selected is below the current room temperature. When the room temperature drops below the temperature you've picked, the heater should come on.
For additional troubleshooting to check your machine is working correctly, you might like to visit our Support page:
http://www.dyson.co.uk/support/am04/am04-whsil
I hope this helps, but if you'd like any further advice, please give us a call. Our Helpline numbers are 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
