Question about Samsung Audio Players & Recorders
I have a samsung giga sound system Hs7000 and the subwoofers is working could they be blowed
Posted by Jason Roberts on
umesh bhatt
    Habit-Forming:
    New Friend:
  • 60 Answers
You have to check the ratings of woofers for wattage they have been designed. Have you got a manual? They would definitely be working up to that mark.
Posted on Aug 16, 2020
How do you reboot a Samsung giga sound system?
no system model stated at all.
this.
Samsung MX-J630 2.0 Channel 230 Watt Wired Audio Giga System (2015 Model)
Aug 16, 2018 | Samsung Computers & Internet
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
How do i use the sound connect on my Samsung hs7000
Google Samsung HS7000 Manual, Samsungs website will have it.
Nov 20, 2014 | Audio Players & Recorders
Trying to get microphone to work for a Samsung giga beat sound
What kind of mic are you using? If it needs Phantom power to work then you're SOL. Invest in a real PA system and you won't regret it. Mackie, Yamaha, Behringer all make good, inexpensive public address systems that will leave your Samsung in the dust.
May 18, 2014 | Audio Players & Recorders
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Subwoofer output no sound...
Check to see if it is properly hooked up to the player, and if it is, then either the amplifier's LFE(Low Frequency Emitter/Subwoofer) channel has failed, or the CPU is not beginning to forward frequencies 200Hz and below to the subwoofer. At 200Hz, the subwoofer adds to the satellite speakers, an then at 110Hz and below, only the subwoofer is playing.
Feb 28, 2010 | Samsung HT-DS630T System
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
Subwoofer???
You should double check the wiring.
Sep 08, 2007 | JVC HX-D77 Shelf System
16 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
