Question about Garden
Where can I find a part for a 2000 Scott riding mower deck for the guide wheel? part #95187-821
Posted by Pauline Dille on
Tom Chichester
    Top Expert:
  • Garden Master
  • 60,313 Answers
Scott would be a possible source.
Posted on Nov 14, 2020
5 Related Answers
Anonymous
SOURCE: weedeater brand riding mower
Weedeater Rider mowers were made by American Yard Products you can contact them for a parts list
Posted on Aug 17, 2008
Mr Kelly G
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
wadembly
Wade Mobley
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: the deck belt on my ride on mower - murray
21a49d6.pngHOPE THIS HELPS YOU LET ME KNOW
Posted on Nov 19, 2009
Testimonial: "Thanks for the info. Really clear diagram and easy to follow which was great."
Anonymous
SOURCE: How much oil does my craftsman riding mower hold? ...
4.5 pints with filter or 4 pints without
Posted on Sep 26, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Why is the front of my deck on my lt 2000 craftman mower all of a sudden digging into the ground
Answer will depend on what mower you have but it sounds like the front wheel height adjuster has slipped or broken.
Sep 19, 2014 | Garden
Where do the springs connect to? On the deck of my Craftsman Lt 2000 riding mower.
main one u need is the one on the engage pulley, it connects to pull plate and the center of the mower deck in the hole in deck. the one foe breaks go to brake bar and belt guid bolt in most cases
Sep 24, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sharp turns mower didgs in ground or on unlevel ground
If you have the owners/operators manual that came with the mower, it will have instructions on how to LEVEL the mower deck. That sounds like your problem. Deck wheels would greatly help also by stabilizing the deck so it doesn't bounce and "float" so much while mowing.
Jul 12, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
