Question about Electrolux Freezers
Check the outside fan motor, oiled, bearing wear side to side and up down. it may the motor going out and working intermitently.
Posted on Sep 19, 2020
Sorry but I know nothing of the new-fangled fridges and freezers with their codes, but what does tend to stop an appliance that otherwise works well is a lack of cooling air around the motor/compressor unit and when the unit works harder during the summer or in the depths of winter when the heating is full on the thermal protection can cut power to the unit.
Cleaning dust and fluff, ensuring all the power connections are clean and tight and not generating heat and ensuring there is adequate air space between the wall and the unit.
Posted on Aug 14, 2020
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
SOURCE: Compressor Stops on Kenmore Chest Freezer
The thermostat needs to be replaced part # 216230400 it is $59.51 at www.sears.com (parts) or it is $52.45 at www.apdepot.com this will fix ya.... both will ship direct to you. If you have to leave you can unplug unit and jumper out the thermostat 2 wires plug back in. This will make the unit run 24/7 until you get the part but it is better than losing the food
Posted on Feb 12, 2008
SOURCE: Frigidaire Upright Freezer
The manual for this unit can be found here.
Posted on Jul 21, 2008
SOURCE: my whirlpool afb 6640 freezer has a red light on
thermostat is defective(loose contact)
Posted on May 09, 2009
SOURCE: I have a frigidaire upright
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Posted on Apr 06, 2010
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Jan 17, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Nov 02, 2014 | GE FUF14SVRWW White 13.7 Cu. Ft....
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Nov 05, 2013 | GE FUF14SVRWW Upright Freezer
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
Apr 27, 2017 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
22 people viewed this question
