Question about Expert Computers & Internet
Is mobile repair possible in dubai with quick and expert service ?Asus mobile has launch with maximum amount of hard disc space as well as there are high amount of internal and external memory.
Posted by su san on
  • Larry Ng
    Larry Ng Aug 14, 2020
    mobile repair
    what does mobile mean,?"cell"
    no PC told is it a PC? nobody can guess what is in your hand, many try but no.
    laptops,notpads,netbooks are all mobile.
    why no post in cell phones and not computers.
    asking yankee's for Dubai? really, i cant fly 6000miles to see. there. nor shop there.
    why not google inside DUBAI, first. ? huh?
    https://www.fixya.com/troubleshoot/brows...
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Expert Master
  • 36,290 Answers
Search google for a local shop
Posted on Aug 14, 2020
WD HARD DISK SERVICE CENTRE IN ABU DHABI
Do not waste your time on servicing hdd. They are dead technology. It costs far less to buy a new SSD than repair old smaller hdd.
If you are trying to recover data, then try
(1) Ensure (Redington) service centre
http://www.redingtonmea.com/services/ensure-services
or
(2) icarefix -
Data Recovery Service in Dubai Abu Dhabi UAE iCareFix
Nov 06, 2016 | Hard Computers & Internet
How do i reformat my asus k42n series but it didn't come with an installer
To speed up your computer/hard disk then you need to maintain your hard disk.
Hard disk maintenance should be carried once a month.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Nov 25, 2011 | ASUS Computers & Internet
Sony ericsson vivaz pro unlock guide,step by simple step
To Unlock the Mobile Phone step by step you can use the Unlock code,You can get the Unlock code at here
Prounlocking.com
and Follow the instructions below and unlock it step by step:
Login ' Register ' Currency Pro Unlocking.com Experts in Mobile Phone Unlocking rrmus-8.gif
Sony Ericsson Vivaz Pro sonyericsson-vivaz-pro.gif Country
Network
Sony Ericsson Vivaz Pro Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson Vivaz Pro mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson Vivaz Pro mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your phone Without a SIM card.
2 - Switch on your Sony Ericsson Vivaz Pro phone.
3 - Compose #pw+CODE+1#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Sony Ericsson Vivaz Pro
Oct 01, 2011 | Sony Ericsson Vivaz Cell Phone
Recieve error message that computer is running low on memory
Hi liciasol,
I see that you system is running low on memory, This can be that you have files in the Hard Drive that almost reach your Hard Drive maximum capacity.
to check you concern we will need to find out what files you have first in your Machine.
  • Check to see if you have programs that you have installed on the machine that you do no use anymore and uninstall it.
  • If there are no files on the machine that need to be remove and you Hard Drive space it taken up by something then we can try and free space from you Hard Drive by doing a Disc Cleanup on your system.
  • To do a Disc Cleanup, click on Start then All Programs, click on Accessories, under Accessories click on System tools then click on Disc Cleanup.
  • A screen should pop up asking you to select a drive letter that you want Disc Cleanup to free space on select the drive letter where windows is installed normally that should be Local Disc C:
  • Once you've selected the drive to free up space on you will see a window Disc Cleanup for (C:) and in the list will be system services or files to delete that take up space on your Hard Drive on the right of each will be Increments of disc space being consumed by each put a check on them except for those that have 0 on it then click on next or OK then a box should pop up Disc Cleanup asking you if you are sure that you want to do Disc Cleanup just click on YES it will start doing Disc Cleanup on your system.
  • If this did not correct fix your concern then I assume the you possibly have Windows Vista on you system.
  • We can try decrease the space the Shadowstorage of VISTA system restore from your machine this is known to take up disc space on the Hard Drive.
  • To perform the said procedure above follow steps below .
  • Click on Start then All Programs, Accessories, right click on Command Prompt and select run as administrator.
  • The Command Prompt window will appear, a black screen with a blinking cursor.
  • Once in the Command Prompt type in vssadmin resize shadowstorage /on=c: /for=c: /maxsize 1gb then press enter once you should get confirmation that the Shadow storage has been resized.
After Resizing the Shadowstorage type exit then enter this will close the Command Prompt window.
Restart your Computer then check your Hard Disc space again to see if any of the disc space has been recovered or free'd on your Hard Drive.
Note: also check if there are backed up files that possible you may have created that you have not burned on a dvd yet, and uninstall unnecessary documents and files from the machine or back up any pictures and videos that you may have on the machine.
I hope that this will be of help regarding you concern, have a nice day.
mvincentc
Apr 13, 2011 | Dell Vostro 1720 (bqcwd1z) PC Notebook
WHAT IS THE MAXIMUM MEMORY CAPACITY THAT MY ASUS A3AC CAN HAVE? WHAT TYPE OF MEMORY WILL GO INTO THE ASUS A3AC? What maximum hard disk size can the ASUS A3Ac running Windows XP can have?
max memory is 2GB ddr2 533 also known as pc4200.
If you dont have sp1 or later, 137gb is the maximum HD your system will see. If you have service packs installed then you can have as big a HD as you want. You may need to use a disc partitioning program to get the full use out of large HD's
Sep 03, 2010 | ASUS A3Ac Notebook
Upgrade my Dell Dimension 4400 Service Tag 43L5811
You can upgrade to practically the maximum available amount of harddrive space as long as the new drive is IDE. The following picture shows the drive you require:
A guide to replace a hard disk for this PC is available here.
As a rule of thumb, you should buy the maximum size hard disk you can afford as it improves the performance.
You can choose from any brand but choose the one with maximum warranty.
PS. There is no need to go into any kind of numbers; just ask the vendor to give you a certain size IDE hard drive eg a 250GB Western Digital IDE hard drive.
Mar 08, 2010 | Dell (078FN) ( 078fn ) 9.1 GB...
Media stuttering and windows startup failure
Hye les_dudis,
How long have you owned this system? Some quick fixes you could try. You have too many services starting up on startup.
Go to Start, Run, and type in msconfig.
Go to the far right tap (startup), disable all, except for your anti-virus. (norton, mcafee) It'll be obvious which one is your antivirus.
Restart, and see if that helps out. If not, try do a system defragmentation.
Start, All programs, accessories, system tools, disk defragmentor. This cleans up your hard drive a bit.
If in the end, these don't help, then if you still have the windows CD, I suggest backing up your info, and swiping the hard drive and installing a fresh windows.
Hope it helps,
-Chad
Dec 11, 2007 | Acer TravelMate 8204WLMi Notebook
Computers & Internet Logo
Top Expert Computers & Internet Experts
Marvin
Marvin
Lawrence Oravetz
ray gallant
Are you an Expert Computer and Internet Expert? Answer questions, earn points and help others
