Question about Canon Office Equipment & Supplies
Canon Pixma iP90V not printing yellow - Canon Office Equipment & Supplies
Posted by Karen Lawson on
umesh bhatt
    Habit-Forming:
    New Friend:
  • 53 Answers
Check the color cartridge. May be a little bit of cleaning at the colour dispensing slit.
Posted on Aug 15, 2020
5 Related Answers
Anonymous
SOURCE: canon pixma ip1300
cannot print on blinking pilot light green and yellow
Posted on Aug 05, 2008
Anonymous
  • 92 Answers
SOURCE: Canon PIXMA iP90v Service error 5100
Error 5100 is mostly because of some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.
There is the purge cap (the white sliding mechanism that the print head parks to when it's not in use) which was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display)
Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
dholaday
  • 226 Answers
SOURCE: waste ink aborber
you can see it and partially clean it without striping the printer down, but after taking the printer top off you can give the whole area a good clean.
The tank is the little plastic tray to the right of the carridge, its about 1cm x 2 and a half and has an absorbant pad inside it held in by delicate rubber wings, the pad can be taken out and a metal plates sits below which can also be removed revealing a small tube throught which ink passes.
You can strip all of this out and clean or just give a quick wipe out with cotton buds without dismanteling too much.
I would recomend that if you have the time and patience then at least do the following;
Take the absorbant pad out and keep patting it on kitchen roll etc until no more in comes off, then gently clean around the rest of the tank with cotton buds, this should be enough cleaning to keep everything happy!
The worst you can do is be a touch to rough and knock the small spring out of place that sits under the tank (you will feel this spring as you prod at the tank) the spring is a pain to get back in place!
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Posted on Jul 21, 2009
dholaday
  • 226 Answers
SOURCE: Service Error 5C00 - iP90v Pixma Canon Printer
Clean it out underneath the printhead & cleaning mechanism first (paper towel), then do the fix routine.
also there are TWO distinct steps to resetting the TWO ink counters in aan iP90. Enjoy.
3-3. Adjustment / Settings
(1) Service mode
The basic operations are the same as those of the i70 / PIXUS 50i.
In this section, destination settings, how to reset the waste ink counter, and EEPROM information
printing, which differ from those of the i70 / PIXUS 50i, are detailed.
1) Turn off a printer. While pressing the Resume/Cancel button, press the Power button.
The LED lights green to indicate that functions are selectable.
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the
alternately lights in either orange or green, starting with orange.)
4) When the LED lights green, press the Resume/Cancel button as many times as you need, to
select the preferred function. (See the table below.) Each time the Resume/Cancel button is
pressed, the LED alternately lights in either orange or green, starting with orange.
(The color red indicates the changes from the i70 / PIXUS 50i.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to step 5) below. Once executing step 5), then, move on to step 6) to select the waste ink counter to be reset. (Different from the i70 /
PIXUS 50i.)
5 times Orange Destination settings Proceed to step 5) below. Once executing step 5), then, move on to step 7) to select a
destination. (Different from the i70 / PIXUS 50i.)
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights green, and the
selected function will be performed. (When the operation completes, the printer returns to the
6) Press the Resume/Cancel button the specified number of time(s), then press the Power button.
Time(s) LED Waste ink counter to be reset
0 time Green Main waste ink counter
1 times Orange Platen waste ink counter
2 times Green Main waste ink counter and platen waste ink counter (at the
same time)
Note: When the waste ink counter is reset, print the EEPROM information as shown below,
and confirm that the value of the counter is 0 %.
8
7) Press the Resume/Cancel button the specified number of time(s) according to the destination
listed in the table below, then press the Power button.
Time(s) LED Destination
1 time Orange Japan: PIXUS iP90
2 times Green Other than Japan (A4): PIXMA iP90
3 times Orange Other than Japan (LTR): PIXMA iP90 (LTR)
Note: After the specific destination is set, print the EEPROM information as shown below, and
confirm the model name.
Print sample:
1:iPXXXX 2:V1.02 3:IF(USB=1) 4:D=004.9 PD=000.0 5:ST=2005/09/27-18:30
6:ER(ER0=1000 ER1=5100) 7:LPT=2005/09/028-09:09 8:PC(M=002 R=000 T=001 D=009 C=009)
9:CLT(BK=2005/09/27-18:30 Cl=2005/09/27-18:30) 10:CH=00002 11:CT(BK=040 CL=013)
12:IS(BK=1 C=0 M=1 Y=1) 13:IC(BK=00000 C=00000 M=00000 Y=00000)
14:Power(SON=00009 SOFF=00009)
15:REG=0 16:UR(A(BKoe)=+01 B(Coe)=-01 C(Moe)=+01 D(SCoe)=-01 E(SMoe)=+01 F(BKbi)=+01
G(CLbi)=+01 H(BK-CL)=+01 I(SCLbi)=+01 J(C-SC)=+01 K(M-SM)=+01)
17:WP=0024 18:CDIN(LG=001 PB=000) 19:MSD(015)
20: PAGE(All=00083 PP=00035 HR+MP=00003 PR+SP+SG=00003 GP=00000 PC=00000 ENV=00000)
21:CDPAGE=00003 IRPAGE=00003 BTPAGE=00003 PBPAGE=00000 22:BAT PAGE=00000
23:EDGE=00083 24:L=00000 25:HEAD Temp=30.0 26:Env Temp=30.0 27:FF(3F 3F 3F)
HDEEPROM
1:V0001 2:SN=0000-3D6B 3:LN(00000 00000 000001 000003 00001 00000 00000) 4:ID=00
5:IL=(BK=000 C=+01 M=000 Y=+01 C2=+01 M2=000 Y2=+01)
Printed items:
1. Model name 2. ROM version 3. Connected I/F (USB1) 4. Main waste ink amount, Platen waste ink amount
5. Installation date 6. Operator call/service call error record 7. Last printing time 8. Purging count
(manual/deep/timer/dot count/print head installation and removal/ink tank installation and removal)
9. Cleaning time 10. Print head installation and removal (change print head) count 11. Ink tank installation and
removal (change ink tanks) count (Bk/CL) 12. Ink status (Bk/C/M/Y) 13. Total ink consumption 14. Power-on
count (soft power on/soft power off/hard power on) 15. Print head alignment implementation 16. User print head
alignment values (Bkoe/Coe/Moe/SCoe/SMoe/BKbi/CLbi/BK-CL/SCLbi/C-SC/M-SM) 17. Number of times of wiping
18. Number of times of camera port connection and removal (Legacy, PB) 19. Number of the maximum printing
intermission in days 20. Number of print pages (total/plain paper/high resolution paper + Matte Photo Paper/Photo
Paper Pro + Photo Paper Plus Glossy + Photo Paper Plus Semi-gloss/Glossy Photo Paper/Card/Envelope) 21.
Number of Camera Direct Print pages (total), number of IRDA print pages (total), number of Bluetooth print pages
(total), and number of Print Beam print pages (total) 22. Number of print pages using battery (total) 23. Number of
borderless print pages 24. Number of print page (L/4” x 6”) 25. Print head temperature 26. Inside temperature
27. Line inspection information
HDEEPROM
1. Version
2. Serial number
3. Lot number
4. Print head ID
5. Ink ejection level (Bk/C/M/Y)
Posted on Jul 23, 2009
Anonymous
  • 92 Answers
SOURCE: Is there a reset procedure for Canon Pixma iP90v
Hi ...
For all Canon printers, if you switch off and unplug the power cable for 30 sec to 1 min, and then plug it back it, it resets the printer ....
Most of the issue related to Canon printer gets resolved by performing the above steps ...
Cheers :)
Posted on Jul 29, 2009
I have a Canon Pixma ip90v. My magenta will not print. The others work fine. Anything color is just in a green , yellow, blue tone. How do I fix this
the prin head is clogged,try to go in the driver and try to clean,if the problem persist change the prin head
Mar 04, 2011 | Canon PIXMA iP90v Printer
Does the PIXMA iP90v work on a Mac? Where can I find the driver?
Hope this helps:
http://canon.driversdown.com/Canon-drivers-download/Canon-PIXMA-iP90v-Printer-Driver_3815.shtml
Good luck
Oct 18, 2010 | Canon PIXMA iP90v Printer
Replacing the drain pack assembly in the Canon Pixma IP90v
You need to remove the top cover, battery holder,shield assembly, power connector, lift the print engine slide out the drain pack and slide in a new one. After re assembly you need to get into service mode and reset the waste ink counter. Simple when you know what you're doing, 30 to 45 minute job.
Dec 23, 2009 | Canon PIXMA iP90v InkJet Printer
How do I change the print cartridges on a Canon Pixma iP90v?
visit the cannon site and support center at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14723#
they will provide you assistance for cannon printer problems. .
Mar 28, 2009 | Canon PIXMA iP90v Printer
Black ink will not print with canon pixma ip90v
Try sending Canon an email through their support website. I had same problem exactly, mine is 1 year old. They sent out a replacement unit for me today. It's worth a try.
Jan 30, 2009 | Canon PIXMA iP90v InkJet Printer
Net to download print drivers for canon pixma ip90v
www.findmysoft.com/drivers/Canon-PIXMA-iP90v-x64-2-00-printer-driver.html - 21k
Nov 04, 2008 | Canon Office Equipment & Supplies
50 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
