Probly a vacuum leak at carb..titen nuts or change gaskets. Buy a haynesmanual on it or small engine repair
SOURCE: My 2 cycle gas trimmer will not start? It's only 2 years old
Have you cleaned the spark plug , replaced it, or the carberation system?
If not, then this could be the problem.
Plug builds up corrosion over a period of time and cleaning is requird. also resetting the gap.
GAs goes stale too to flush out the old gas and put new gas.
SOURCE: I LOST THE MANUAL TO HUSQVARNA 128L TRIMMER HOW
Here's the link to the manual: Husqvarna 128l Manual
SOURCE: Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
SOURCE: Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
