Question about PRINTER Office Equipment & Supplies
Is there a windows 10 Driver for DPU-414 thermal printer download
Posted by Donald Robinson on
  • PRINTER Master
  • 6,164 Answers
I can't find any Windows 10 drivers for the SII DPU-414. According to the Technical Details tab at https://www.compart.pl/en/produkty/mobile-portable-thermal-printer-dpu-414/ , this thermal printer has drivers for Windows 2000, XP, Vista, 7 and 8. This suggests that the Windows 7/8 drivers are unsigned and will not work with recent Windows 10 versions. Microsoft insisted on signed drivers starting with Windows 10 Anniversary Update in 2016. (In 2016 there was a way to test an unsigned driver in Windows 10, see Google ("windows 10 unsigned drivers"). I don't know if these still work.)
I hope this helps. Filling out the form on the Compart.pl page Inquiry tab may let you get a link to the older drivers for the DPU-414. You can try using a virtual machine with Windows 7 or 8 under Windows 10 Pro or Enterprise, if you can find a license for the OS.
Posted on Aug 14, 2020
This printer is connected to a device that on occasion will print data in the middle of the line with incorrect values when compared to the display. When the device is told to reprint, the data is not...
please check the DATA cable and printer driver installed in the system. these are two things often responsible for junk printing.. what kind of printer iit is ? laser ? inkjet or Dot matrix?
Sep 26, 2013 | Seiko DPU 414 Matrix Printer
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
Where do i get the ethernet driver for my mpc clientpro 414
ClientPro 414 Ethernet Driver >>Click here to download Windows XP Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN DriverClick here to download Windows XP x64 Edition Broadcom NetXtreme Gigabit Integrated 10/100 Fast Ethernet LAN Driver
Oct 21, 2011 | MPC Computers ClientPro 414 All-In-One PC...
I have a DPU-414 Thermal printer that just won't get dark enough. I have already changed the switch settings to its highest density 121%....
Access and clean the area where the paper runs over the heating/printing element. This area picks up foreign substances and bakes them so that the paper no longer makes proper contact with the print head. Use something like an alcohol based solvent to remove any build-up in this area.
May 03, 2011 | Seiko DPU 414 Matrix Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
I have windows vista and when i go to install the printer i cant find this model dpu 414 help?
This printer isn't supported in Vista. All you can do is to install a Virtual machine, XP on it and the printer in that XP.
Aug 30, 2010 | Seiko DPU 414 Matrix Printer
Calibrate a DPU3445
go to this website:
http://sii-thermalprinters.com/thermal-printers/mobile-printers-DPU-3445.aspx
it is seiko's official website, but you will need to register to be able to download the manuals.
good luck.
Dec 02, 2009 | Seiko DPU 3445 Thermal Printer
46 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
William Freigruber
Level 1 Expert
Marvin
Marvin
SamPan
Level 1 Expert
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
