Question about Refrigerators
Ice is building up on the right front freezer door. It only happens by the door, along the slide bracket, and a little on the top of the door. The seal on the door appears to be good. Any ideas?
Posted by Mike Bakez on
Vernon Taylor
  • Refrigerators Master
  • 6,819 Answers
Localised ice buildup often signals a localised insulation breakdown and the proof will be a cold spot on the outside of the cabinet.
Posted on Aug 15, 2020
5 Related Answers
mikedurland
Mike Durland
  • 481 Answers
SOURCE: my freezer door seal doesn't
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 02, 2008
Anonymous
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
Techsim
James
  • 59 Answers
SOURCE: Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Posted on Nov 04, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
jcroyle750
SOURCE: GS6NBEXRSOO model whirlpool gold 2005.
Same problem with my GS6SHEXN002. 50 degrees in the refrigerator 10 degrees in the freezer. Everything appears to be fine it just doesn't get any colder than 50Deg. Came on gradually over a a month or so. Still no solution...
Posted on Jun 23, 2011
Ice maker stopped making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 15, 2013 | Samsung RF263AERS (258 cu ft) Bottom...
88 88 fault on Samsung rf265abwp
Broken wires at the ice maker can cause that problem. It could be another temperature sensor as well of course. Check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Sep 12, 2013 | Samsung RF265ABWP (25.8 cu. ft.) Bottom...
Ice maker not making Ice.
z
2q==
z
Aug 18, 2013 | Samsung RS2630WW Side by Side Refrigerator
Model RS267TDWP/XA. Not making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. On my model RF265AABP, I check the digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Aug 11, 2013 | Samsung RF265AA Bottom Freezer French Door...
I can't get the ice maker to come on. What can I do?
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. This solution applies to a different model, RF265AABP, but may be similar. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
May 03, 2013 | Samsung RB2155 Bottom Freezer Refrigerator
Hi My beko frost free freezer has been building up ice in the little grid thing at the top of the freezer. The temperature was also driopping ( to 8) and so I have put it on fast freeze to raise temp. What...
check the door seal on the top of the door if not sitting flat to the frame it will encourage frost to build up (inside the little grid thing)which will stop the rest of the freezer from cooling enough.
Jun 14, 2010 | Freezers
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
RF266ABPN French Door Firdge/freezer Ice maker sensor
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung model RF265ABPN waxy looking piece fell into ice tray
Jul 05, 2009 | Samsung RF265AA Bottom Freezer French Door...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
