Question about Air Purifiers
Link to purchase fragrance cartridge refills for Amcore Am40 model purifier ionizer
Posted by Kaye Potter on
3 Related Answers
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: No problem but can't find replacement filters
Hi just a tip for you, if you can't find a filter you can buy filter media at your hardware store such as Home Depot, and have it cut to fit. It is good material made to replace any type filters. Sincerely,
Shastalaker7
Posted on Dec 05, 2009
Anonymous
  • 3 Answers
SOURCE: i need an ionization wire for my ioninc breeze
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Posted on Jun 30, 2010
Lynne
  • 3 Answers
SOURCE: I have a Brookstone Model
I have them listed on ebay
Posted on Dec 06, 2011
Tip
Sharper Imaage Ionizers
Ionized air purification systems have been proven to be ineffective for cleaning the air. These reports have been published by Consumer Reports as well as the EPA. Sharper Image filed a lawsuit against Consumer Reports and lost. They were ordered to pay Consumer Reports legal bills as well.
Sharper Image issued a recall on all Ionic Breeze Ionizers and filed for Chapter 11 at the same time.
Ionizers have been proven to create an ozone that is harmful to anyone with breathing problems.
Here is a link to the EPA report
Here is an article from CNN.com about The Sharp Image
Support for Ionic Breeze isn't possible since Shaper Image has recalled the product.
Your best bet to keep the air clean in your house is to use a hepa filtration system.
on Jul 12, 2008 | Sharper Image Professional Plus Ionic...
I need to know where to purchace the fragrance for the oreck air 7?
Below is a link to Oreck's website where you can order fragrance packets for your air purifier. If there's an authorized Oreck repair facility in your area, they may carry these as well.
Oreck Parts&Accessories
Jan 13, 2012 | Oreck Super Air 7 Air Purifier
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
I have model S1730, is it possible to replace ionizing wires and where can I purchase such a wire?
I have replaced those wires with chrome plated wire, stainless steel wires and platinum wires. Nothing lasts very long (weeks to a few months). There are no parts available for these machines as far as I know.
Charlie
Jan 07, 2011 | Sharper Image Ionic Breeze GP SI730 Air...
How do I clean the ionizer when the check filter light turns on?
with no power to the unit take a soft moist cloth and wipe easy all the wires are flat plates
Apr 14, 2010 | Brookstone Ionizer/ Air Purifier Air...
Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Jun 06, 2009 | Rainbow Rainmate Air Purifier
Ionic breeze model S1637 needs cartridge brushes that clip in on the bottom end (this model has two ) where can i purchase these? regards, jim
If you're talking about those little plastic tabs at the bottom, they aren't important. Their job is to wipe the ionizing wires when you take the grid out or replace it.
You might be able to pick up spare parts if you scour eBay long enough.
Mar 03, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Ionizer
IONIZERS to not PURIFY indoor air. IONS are either NEGATIVE or POSITIVE. In this case, the NEGATIVE IONS are the 'GOOD GUYS!"
An ionizer will usually put some negative ions into the air while trapping, just like positive/negative magnets would do- SOME of your airborne live contaminates onto a metal plate inside the ionizer. When you pull out the plate with this smorgasborg of contaminates to wipe it, some of them can go airborne again, plus you have a dirty cloth ripe with contaminates on which you should then throw away. You haven't PURIFIED your air-you've just added some negative ions to your air, which will make your air feel light and lively- but still not PURIFIED.
Our SUN AIRE purifiers not only PURIFY indoor air SAFELY and EFFECTIVELY like SUNLIGHT, but one of the side-benefits is that we replenish your NEGATIVE ION balance in your air because of our SUNLIGHT process of purifying your air.
We DO NOT LIVE in our ductwork, therefore, our SUN AIRE purifiers purify your air in your living spaces FIRST and then the allotropic oxygen can be sucked through your ductwork.
POINT-OF-CONTACT is the key to our SUN AIRE purifiers effectiveness. We recommend you place your SUN AIRE purifier as FAR AWAY from your cold air return as possible because we want you to use the allotropic oxygen FIRST, before it's sucked through your ductwork.
Thanks for your question. Please let us know if we may assist you.
www.betterair.com
Oct 04, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Air Purifiers Logo
24 people viewed this question
Top Air Purifiers Experts
ray gallant
Tom Chichester
Are you an Air Purifier Expert? Answer questions, earn points and help others
