Question about Red Computers & Internet
Hi my gal got a spill on my explora decoder and it shows red exclamation
Posted by Nathi Mango on
  • 1 more comment
  • Larry Ng
    Larry Ng Aug 12, 2020
    what computer is this., make and model.
    both matter.
    spilled what? coffee, cola , or pool acid?
    it is really not a computer but TV stuff.per
    "DSTV Explora decoder offers full Personal Video Recoder (PVR) functionality. PVR enables you to record TV"
    Spilled where the main large unit or just the silly clicker remote.
    to clean a remove if will not dry out easy
    we strip and clean it with IPA< (alcohol)
    then air dry it, even put it in attic all day hot. (mines 100f now) and then put back together, and it works now.
    learn to post TV stuff in TV forum.
    or buy a new remote.
    next time post here for TV stuff not comptures
    for 10x faster and omg accurate answers.
    https://www.fixya.com/troubleshoot/brows...
  • Anonymous Aug 12, 2020
    if spill was drink tequila it is doomed.
    1 tequila , 2 tequila 3, tequila floor.
    step one remove all A.C power and batteries from the DROWNED DEVICE.
    avid cleaners like 409 or janitor in a drum.
    use only IPA or pure
    Ethanol (also called ethyl alcohol, grain alcohol, pure drinking alcohol, spirits, or simply alcohol) pure,
    the problem worst is keypads are very hard to dry out. (rubber seals) and takes hard work.
    Dismantled.)
    buy a new remote.
    one cross fingers fix
    put remote in attic for 24hours, summer answers. (hail Mary fix)
Andrew Taylor
    Top Expert:
  • Red Master
  • 34,068 Answers
Switch it off straight away and leave it somewhere warm for 24 hours.
https://www.google.com/search?q=explora+decoder
Posted on Aug 11, 2020
    sad how poster failed to say which end fails. nor how.
    dropped remote in commode>?
    or spills to main box huge.
    sad.
    as in drowned my TV Set-top remote, gee.
    if yes 24hrs in attic is simple fix, if lucky.
    some drinks are full of phosphoric acid.
    COLA AND not good that, never is that.
Hi, We have a top loading dispenser. Problem is the bottles at Walmart have a screw on lid and therefor the water spills out before we get it situated on top of the dispenser. Thank you, Laura
Not sure what you have. We buy the 5 gal water at Walmart. We pull the tape sticker off top of bottle and put on our dispenser and it never spills. If your 5 gallon water bottle screws on I have never seen one of those. Sorry if I am misreading or don't understand what you have or what you are talking about.
Oct 07, 2018 | Water Dispensing & Filtration
Is there a 210,00 gal oil spill in S. Dakota>
yes there is
Keystone pipeline leaks 210K gallons of oil in South Dakota - ABC News
abcnews.go.com/.../keystone-pipeline-leaks-210k-gallons-oil-south-dakota-51208130
1 day ago - s Keystone pipeline leaked an estimated 210,000 gallons of oil onto agricultural ... A leak and spill in southeastern South Dakota in April 2016 ...
Keystone Pipeline leaks 210,000 gallons of oil in South Dakota - CNN
www.cnn.com/2017/11/16/us/keystone-pipeline-leak/index.html 9 hours ago - A total of 210000 gallons of oil leaked Thursday from the Keystone ... This is the largest Keystone oil spill to date in South Dakota, Walsh said.
Keystone pipeline leak spills 210,000 gallons of oil in South Dakota ...
https://www.cbsnews.com/.../keystone-pipeline-leak-spills-210k-gallons-of-oil-in-sout... 1 day ago - Last Updated Nov 16, 2017 9:13 PM EST. AMHERST, S.D. -- TransCanada Corp.'s Keystone pipeline has been shut down after it leaked an ... 210 00 gal oil spill in Dakota Google Search
Nov 18, 2017 | Cars & Trucks
What years were the Rheem 81v40d produced?
You can find age of water heater from serial number located on label on side of tank.
Label also shows tank size, and tank wattage and element wattage
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Serial number decoder:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
For example Rheem serial number 0790...
First 2 digits are month 07 July
Next two digits are year 1990
Rheem site does not show 81v40d
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Dec 26, 2010 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Okay. I have a DSD 1110 (+2) decoder. The decoder does not want to scan. It just shows a number 8 first then dL then a number 1 with a line turning around and then the numbers 8118 and then it starts again...
hi, been having the same problems that you described and im not sure what to do. electricity was down for about 12 hours and when it returned i noticed the problem as well as all 3 indicator lights (red,green,yellow) showing on the front display. im just wondering if you found a solution. what did you do and did you eventually fix the problem?
Oct 02, 2010 | Computers & Internet
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
Computers & Internet Logo
23 people viewed this question
Top Red Computers & Internet Experts
Marvin
Marvin
Vernon Taylor
ChinthakaJ
ChinthakaJ
Are you a Red Computer and Internet Expert? Answer questions, earn points and help others
