Question about Kenmore Refrigerators
I have a Kenmore Elite grab and go refrigerator and the bottom of the fridge keeps building up ice and then leaks on the floor.
Posted by Richard Susice on
Vernon Taylor
  • Kenmore Master
  • 7,428 Answers
When that happens the cause is often a blocked defrost drain.
After each cooling cycle a panel heater is switched on for a short time to melt the ice that has formed over the evaporator and the resulting water droplets are channeled into a drain that dispenses them into an evaporation tray attached to the motor/compressor unit.
A flexible curtain wire is what I use to clear the drain.
Posted on Aug 09, 2020
Testimonial: "Can you tell me where the drain is located?"
  • 6 more comments
  • Richard Susice Aug 09, 2020
  • Vernon Taylor Aug 10, 2020
    Drain is usually at the back of the cabinet. About halfway down there is generally a funnel shape moulded into the plastic cabinet liner designed to channel water droplets into the drain.
  • Richard Susice Aug 10, 2020
    OK I cleaned that. There was actually two of them. One was clean and the other was partially plugged but not completely. I cleaned the fins on the coil the best I could. They had a lot of dust on them and I cleaned the fan. The temp is better. It got down to 36 with the setting at 34, but I am still getting the ice in the bottom of the fridge.
    If you cleaned and dried the inside of the cabinet and removed all traces of ice and now meltwater is all going down the drain - it creates the question of where the water is coming from that is causing the ice?
    It is early to judge as after having the door open for a while it will take around 24 hours for the temperature to stabilise and the natural condensation to reduce to a minimum. If unnatural localised ice buildup persists it indicates the cabinet insulation has broken down in that area.
    Thank you very much for all your help. It is greatly appreciated.
    Is there a vacuum to seal the doors tight?
  • Vernon Taylor Aug 11, 2020
    No. These days and for a considerable time fridge and freezer doors are held firmly closed by a flexible magnetic strip embedded in the plastic door seal. It relies on good door alignment and a smooth metal surface to seal against so it is important not to allow spillages or moisture to cause corrosion of the surface at the bottom. I find a spray with silicone around the surface and the seal helps keep the seal efficient.
  • Richard Susice Aug 11, 2020
    Thank you so much.
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 18.5 cu ft fridge - heavy condensation/ice build up
mam please check the settings of the freezer and the refrigerator settings should be in normal mode and if u find it in normal mode then the problem is here the temperature controler is not responding to cutt off and cutt in the freezer so please check this operation.
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
