Question about Samsung Refrigerators
Samsung refrigerator model rf217acpnxaa. Top of fridge cabinet reading 38 degrees (as set), bottom of fridge reading 10 degrees. Could circulating fan not running cause this temperature disparity?
Posted by chad richards on
David Spradling
    Top Expert:
  • Samsung Master
  • 11,652 Answers
Yes
Posted on Nov 01, 2020
Freezer goes -9 and fridge goes to 40 I have set it to 0 for freezer and 34 for fridge it changes on its own
Depends on type of refrigerator freezer you have, but you need to realize that the evaporator (cooling coils) are in the freezer, and the cold air produced in the freezer is then circulated via an evaporator fan into the refrigerator section. The thermostat the cycles the compressor motor is located in the refrigerator, and the compressor will run until the temperature reaches the desired level in the refrigerator. On most units, the freezer temperature setting simply regulates how much cold air is circulated into the refrigerator.
What you are describing is that the freezer is working fine (almost too good), but the air is not properly getting to the refrigerator area. Several things can be causing restricted airflow, including a faulty evaporator fan, icing of the evaporator coils because of a malfunction in the automatic defrost system. Check to see if there is frost or ice build up in the back or bottom of the freezer. The proper temperatures should be around 0 F for the freezer and 38-40 degrees F for the refrigerator.
Feb 25, 2015 | Refrigerators
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
I have just purchased the above unit and has been plugged in now for 24hrs with no food, the high humidity warning sign Is illuminated constantly Is this correct?? Also I have yet to witness the operation...
You didn't include a manufacturer or model, so I can only offer general help with your problem. If you choose to provide this info later, you may get better, more specific help. The freezer compartment contains the cooling coil for the freezer and fresh food compartments. This fan in many fridges are not visible - but yours may be. Yours may also have circulation fans specifically for moving air around the fresh food compartment.
Generally, the coil is located in a protected area of the freezer (behind the back panel). The fan is arranged to pull air from the freezer floor through the coil to be cooled and blown out the top of the freezer compartment. Openings between the freezer and fresh food compartment allows a portion of the cold air to be blown into the fresh food compartment.
The first thing to do is to see what the temperatures are in both compartments. The fresh food should be about 36 degrees and freezer -10 to 0 degrees Fahrenheit. Place a glass thermometer (capable of displaying 32 degrees and up) in a glass filled with cold tap water, and place in the fresh food compartment. Place another thermometer in the freezer (capable of reading -10 and up). You can also use thermometers designed for fridge / freezer temperatures if you wish.
If there is nothing in the fridge and the door remains shut, the temperature should be seen in an hour or so. If the temperature range is obtainable, it is not likely that there is a humid condition INSIDE the fridge. You may have moisture collecting on the OUTSIDE of the fridge near doors, etc. If so, locate a humidity switch and turn it on. Many manufacturers provide this switch to turn on electric heaters in the outer part of the fridge cabinet where moisture tends to form in humid climates. These heaters operate to evaporate the moisture on the cabinet and usually come on when the freezer defrost circuit is on.
I hope this helps and good luck!
May 16, 2011 | Refrigerators
My GE Bottom Freezer Refrigerator Model:PFS22SBSSS The Refrigerator is not cooling, however the Freezer is mantianing proper temprature at 0 degrees. The temp on the fridge is reading 60 degrees on the...
Your problem is almost surely caused by the failure of the fan that should circulate cooled air from the freezer section to the refrigerator. If you check for vents, normally in the rear of the fridge, and hold your fingers in front of them while you hear the compressor running, you should easily feel cold air coming from them if the fan is running.
To determine whether you want to have it serviced or replace the fan yourself, try entering your model number on the Sears PartsDirect website to see if your unit is one of thousands of non-Sears appliances in their library. If they do, then you will find an illustrated parts drawing with part numbers.
Sears PartsDirect
Sep 06, 2010 | GE PFS22SBSSS Stainless Steel French Door...
Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Jul 24, 2010 | Samsung RB215LASH
The lower part of my refrigerator is freezing everything (temp. approx. 30 degrees). The upper part of the refrigerator is almost 45 degrees.
it is possible that the circulating fan is knacked. cold air drops so the bottom of your fridge so will be alot colder than the top, especially since the air will no longer be circulating.
Dec 04, 2009 | Amana ATF2136ARB 33" Top Freezer...
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
73 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
