Can i use anotheer stereo or tv remote to control my TEACSR100
Posted by Janeth Lozano on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 33,973 Answers
How to connect speakers for more sound
There are lots of approaches to getting better sound from your TV. I happen to use my stereo as the TV has regular phono connectors that are compatible with my stereo and they're adjacent. Newer stereo amplifiers can simply use the HDMI output from your TV for the sound and have the advantage of being able to control/switch other video and audio devices like DVD players and game consoles. This type of setup is also good for home theater-style sound with multiple speakers around the room.
I use a universal remote control to turn on all my devices and control the stereo's volume while also being able to change channels etc.
Another approach is to purchase a soundbar from Best Buy or other electronics retailer. The generally fit just under the TV and can provide reasonably good sound.
Jul 02, 2016 | Televison & Video
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Samsung HT-P38 remote will only turn TV on and off won't control the stereo receiver, why?
If stereo recieiver is part of your Samsung HT-P38, remote should have a function to contole it. Check user's manual
Samsung HT P38 Instruction Manual
If you are following correct steps for use of your remote and still can't manage your stereo receiver, probably something is not working correctly., most probably your remote. Maybe you could get it checked with an authorized SAMSUNG repair service
Jul 14, 2014 | Samsung TV Remote Control
Need original remote control & owner's manual for GE XS Stereo Commercial Skip TV, Model #27GT616
To get its original remote control and user manual, you have to contact the nearest authorized service center for GE
Sep 01, 2012 | Televison & Video
Need a code to program my philips remote control to my apex tv.
Be advised that if the remote and TV are more than ~2-3 years different in age, there will probably be no code available. There is no standardization of the code sets and they change even from one model TV/Stereo/DVR etc. to another. Even 'learning' remotes refuse to learn from all IR remotes.
Secondly, always include ALL model numbers in your query if you expect to receive any reply worth your time.
Jan 28, 2010 | Philips Televison & Video
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I have lost my remote
Original and replacement remotes: www.remotes.lt
Sep 07, 2009 | Televison & Video
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
