Question about KitchenAid Refrigerators
My kitchenaid superba Modelo No. KGST307HBS1 sometimes won't turn off and sometimes after is turned off, it will turn on by itself. ? What is going on?
Posted by Maria Isabel on
ray gallant
    Top Expert:
  • KitchenAid Master
  • 69,187 Answers
WE CAN NOT GUESS AS IT NEEDS TESTED BY A LOCAL SHOP
Posted on Aug 07, 2020
5 Related Answers
Anonymous
SOURCE: kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Posted on Oct 09, 2008
Paulo
  • 188 Answers
SOURCE: Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Posted on Feb 18, 2009
Anonymous
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Posted on Aug 28, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Posted on Dec 22, 2009
Anonymous
  • 254 Answers
SOURCE: I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Posted on Feb 12, 2010
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
No ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaide Superba Side by Side Refridgerator-alarm keeps going off
Its called a Manometer. You shut the gas off and unscrew a alen/ hex head screw in the outlet side of the regulator. Screw the end of the manometer in then turn the gas on. turn the temperature up and down and the gas pressure should go up and down with the flame.
Jan 26, 2008 | Refrigerators
Kitchenaid superba disposal
IF THE WATER IS NOT IN THE BASIN OF THE DISPOSAL, THE PLUMBING IS THE PROBLEM, NOT THE DISPOSAL.
YOU CAN TRY TO TAKE THE TRAP LOOSE AND SEE IF THERE IS ANYTHING STUCK IN IT OR YOU COULD TRY SOME DRANO IN THE SINK WITH THE WATER STANDING IN IT. THE TRAP IS THE PART OF THE DRAIN THAT RAISES UPWARD TO HOLD WATER. IT KEEPS THE SEWER GASSES FROM COMING UP THROUGH, BUT IT ALSO IS A GOOD CATCH ALL FOR HEAVY ITEMS AND GREASE.
LOOSEN THE NUT LOCATED AT EACH END OF THE TRAP. HAVE A BUCKET UNDER IT TO CATCH ANY WATER THAT DRAINS OUT. REMOVE THE TRAP AND SEE IF THERE IS AN OBSTRUCTION IN IT.PRESSURIZED AIR WILL SOMETIMES CLEAR AN OBSTRUCTION IN A DRAIN LINE ALSO,
Jan 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Sep 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
63 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
