Will the power supply or main board need to be replaced in my tv to fix an issue?
Posted by Dang Dang on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Televison & ... Master
  • 36,397 Answers
Without testing we dont know
Posted on Aug 05, 2020
LG LED tv backlights not coming on. Replaced power supply board and LED strips, did not fix. Should I move to replacing main board? Model # 42LN5300
Wow, a master replied, if you need to buy TV accessories, you can take a look at this website:www.abctay.com
Jul 09, 2018 | LG Televison & Video
How to fix no image problem on my Samsung TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 07, 2016 | Samsung Televison & Video
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Vizio sv421xvt issues
It sounds like a main board issue but could be a power supply issue. I will tell you from my experience with Vizio TV's, main boards are more likely to fail than power supplies. But to be sure, you will want to either get a diagnoses or if you're handy do a little troubleshooting. The power supply and the main board are not cheap so you will certainly want to be sure before spending any money.
Nov 24, 2012 | Vizio SV421XVT 42 Class LCD HDTV - 1080p,...
I had to heat up the tv from behind it and it would turn on. Now, how do I fix it.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress from www.shopjimmy.com
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Sep 27, 2011 | Sanyo DP50747 50 in. Plasma TV
My tv wont turn on at all i have no green light to show it is even on what can i do to fix this issue
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
I hope this helps.
Regards.
Jul 10, 2011 | RCA L32HD31 32 in. LCD HDTV
OUR TV JUST TURNED OFF AND NOW WILL NOT TURN BACK ON...THE POWER SOURCE IS GOOD TO THE TV WONDERING IF IT IS A FUSE AND HOW TO FIX
I hope this helps.
Regards.
Jun 13, 2011 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Plugged in my tv. It popped and now won't turn on. Is it the power supply or an issue I can fix easily
first, make sure the Tv is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your Tv is certainly having a power problem.
All these can be checked on the power supply board.......
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Yours sincerely.
Elect_Comp.
May 14, 2011 | Philips Televison & Video
My Samsung SP-R4232 has some type of power supply issue. I called a tech who came out and verified it. He thought it was the main power board, but wanted $400 to fix it when I found the part online for...
U replaced the tv power supply board,the board u replaced,that is the board where the power a/c cord plug into it?Check ur old power supply board,examines all parts,see if u have any capactors parts are bulging or puffing up on it tops.Yes,than it is power supply board issue.But by replacing the power supply board only get 50/50 chances for the tv to work.Might be the problems,might not be the power supply board issue alone some times.The chances are tv Tuner signal board is dead also.That the board,where the tv incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Toshiba Regza 40XV645U garbled sound. Have to turn TV off and back on to resolve. Recurrs after an hour or so.
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
Nov 09, 2009 | Toshiba 40XV645U 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
