Question about Lands Phones
Gigaset c620a phone has no dialling tone - Lands Phones
Posted by anne gibbons on
Does the gigaset c620a have touch tone capability
All modern phones have touch tone capability. Your serving central office should have this facility, so you can use it.
Feb 22, 2015 | Lands Phones
Why can't I get a dialling tone?
See if you can borrow another phone known to be working, or plug your phone into someone elses home line to check out there is no fault in your phone
If all is well then you will need to contact your phone service provider.
May 20, 2014 | Gigaset A400 Dect Cordless Phone - Single
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
My Gigaset AL28H phone is working properlybut I do not get a dialing tone. When I press the green button the previously dialled number is redialled. Can you advise if I have simply set the phone...
this is either because you have completely reduced the volume at which you hear whoever you are talking to or your speaker is faulty.if you are able to hear whoever you are talking to clearly after the person picks up then there is no problem with your speaker but if not that could be it. secondly, you can try using an earpiece and see if it works(ensure the earpiece is working too) if you can hear the person too,i suggest you go thru the phone for any settings have to do with dialling tone(if it has any) or you contact your network provider.hope this helped?
Oct 21, 2010 | Cell Phones
Siemens Gigaset C1 telephone
Solution not found, but putting it down to the age of the apparatus.
Thank you for getting in touch.
Jul 22, 2008 | Lands Phones
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
