Question about Whirlpool Washing Machines
Whirlpool stylemaster 4217141 REV A Is out of control during spin cycles. Do I have a bad shock? Is there and online service manual??
Posted by Chris McCarty on
Tom Chichester
    Top Expert:
  • Whirlpool Master
  • 57,293 Answers
1. Your machine may not be level in both directions.
2. Contact Whirlpool directly to inquire about the manual.
Posted on Aug 04, 2020
1 Related Answer
hkapptech
  • 183 Answers
SOURCE: Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Posted on Jan 03, 2012
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
Nov 13, 2016 | Whirlpool Washing Machines
How do i fix a Whirlpool stylemaster 4217141 REV A whose cycle is not completing and that will not spin the tub or drain.
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Aug 02, 2014 | Whirlpool Washing Machines
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
Oct 15, 2013 | Washing Machines
Check the water valve for continuity. Also check the screen on the cold water side to see if it is clogged. That is what I would do.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 05, 2013 | Dryers
Jan 02, 2012 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Whirlpool Washing Machines
Washing machine won't spin
I think it's the capacitor. The capacitor live under the top of the washing machine, two screws, and measures about 7"x2". The capacitor gives the drum An extra 'bump' when all the weight is in It. Remove the capacitor with a pair of pliers or a spanner but under NO circumstances, touch the two connections at the to of the unit, you will get one hell of a shock! Run the machine empty with the top off and it should run properly.Then refix the top. Job done,
Jul 23, 2009 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Spinning doesn't take place during spin cycle
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Apr 21, 2009 | Washing Machines
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
