Question about Home
Hi, I have two radio controlled wall clocks one is still working on the original battery and the other eats batteries, first the second-hand stops and some weeks after that the whole clock stops.
Posted by David Potter on
Andrew Taylor
    Top Expert:
  • Home Master
  • 34,068 Answers
Use Lithium Ion single use batteries for durability or rechargeable batteries for cheap cost.
Also check if there is a setting for how many times it checks into the Time Server. It will deplete the battery faster if it is doing once every 30 seconds rather an once a week.
Posted on Aug 04, 2020
ray gallant
    Top Expert:
  • Home Master
  • 69,233 Answers
THEN THROW THE NON WORKING ONE AWAY WE DO NOT KNOW ANY FIX FOR THEM
Testimonial: "Thank you Ray but its too nice a clock to throw away"
Clock runs only when horizontal
A bit of wd40 or similar in the working gears, they get a bit of something in there and clog, in kitchens they get fat deposits..
Mar 04, 2018 | La Crosse Radio Controlled Atomic Clock
Minute hand on atomic clock keeps moving
Take the battery out and put it back in the opposite direction. Wait 5 seconds. Put it back in the correct position. The minute hand will go around very fast and eventually come to a stop. This can take a couple days. That means it is waiting for a radio signal from Colorado. For a better signal, place the clock in a window that is facing Colorado. The minute hand will begin to spin very fast until it stops at the correct time. Again, this could take up to 2 days.
Sep 12, 2012 | Staples Round Atomic Wall Clock; 14
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
Mar 25, 2011 | La Crosse Radio Controlled Atomic Clock
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
We now have two wall clocks that have stopped. Replacing batteries has not worked. Are they repairable? Can we get new or reconditioned movements?
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Mar 14, 2011 | La Crosse Radio Controlled Atomic Clock
My Lacrosse radio controlled clock (IECLR6) has begun performing erratically. First it set itself 35 minutes slow. A few days later it began advancing the time rapidly and continually. I removed the...
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
Aug 24, 2010 | La Crosse Radio Controlled Atomic Clock
My Emerson CKA1000 clock radio worked great for years, but now it eats the battery back up, battery will go dead in a month or so and if I set the alarm for radio it will show the 20 ne message when the...
Sounds like the main power supply may have gone bad and you are strictly running off the battery. This is why it works fine for a while when you install a new battery, that is until that battery drains and gets too low. The radio won't play because it is preserving battery life. I bet you could unplug it from the wall and would get the same results. You essentially have a battery powered clock right now. To test this theory simply remove the battery, plug the clock up and see if it comes on. My guess is it will only work with the battery installed.
Jul 23, 2010 | Emerson CKA1000 Clock Radio
My Barolo atomic wall clock (with hands) stopped working (I think the battery died). I replaced the battery, and now the hands just keep going around without stopping. I have removed & replaced the...
Try to move the clock to a different place. Atomic clocks work by receiving a radio signal. If it has no reception, it may do that. However, I would suspect that no reception would lead to it not setting at all(at least based on the ones I've seen) and it may be something wrong with it (i.e. having difficulty detecting where it's hands are) Good luck.
Jan 03, 2010 | Kitchen Appliances - Others
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
