I cant seem to fix the volume of the tv with my remote. I tried the volume of the television remote when I used movie from USB or even HDMI, butnit wont work when I used the cable tv.
Posted by Domdie Tarranza on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,286 Answers
Your cable TV remote control cannot adjust volume on your TV. All remote controls are mot interchangeable.
Posted on Aug 03, 2020
5 Related Answers
Anonymous
SOURCE: X2Gen MV37R Flat Panel TV Sound & Universal Remote
I also have the issue with the sound out of sync highly annoying...is this an HDMI issue?
Posted on Oct 06, 2008
Anonymous
SOURCE: Can't program my cable remote to work with tv volume
So I had the same question and found this web page.
http://support.cox.com/sdccommon/asp/docview.asp?sprt_cid=bd70d786-6d94-45e7-9fb7-7fc5345157d4&sprt_verb=preview&sprt_ct=sprt_resource&fname=Raw+Document&sprt_usage=false&sprt_rate=false> target=_blank”
So I hope this helps
Posted on Oct 18, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
Anonymous
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
Anonymous
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
Are spectron tv compatible with chrom cast device to stream movie???
Try the hdmi settings in your tv, and select different modes, eg 720i 720p ect
Jan 22, 2015 | Spectroniq PLTV3250 32 in. LCD TV
I have a samsung tv and for some reason the volume control is always on the screen even though i am not using the volume and it prevents the remote from working other then that everything seems fine. I...
did you try without the remote ?
remove the battery from remote and check.
did you try with another remote ?
did you try with other input sources ?
did you try factory reset of tv
Dec 18, 2014 | Samsung Televison & Video
Dvd player dvd does not show on tv screen
swop the TV back over to what ever you use for watching TV i.e.........HDMI 1 / HDMI 2 / AV 1 / DTV / etc.
Use the AV or SOURCE button on the TV's Remote, not your receivers remote or SKY remote.
Feb 12, 2014 | Pioneer BDP-LX52 Installed
My buttonson my tv arec all volume and my channel is stuck on a setting and i cant get any channels.will a vcr fix the problem? will it put my tv back to hdmi?
If using cable you may be able to route signal to rear audio and video inputs--doubt a vcr will help.
disconnect power from set and or a box if used--wait several minutes and power up again--HDMI can cause issues and does not like connections being made if units are on.
Dec 03, 2012 | Televison & Video
Very weak sound on television from dvd. player recently bought. It is a Silvercest KH 6524 player and some official dvd discs.. Even using maximum volume of my t.v. , a flatscreen Samsung and my...
Some brand name of the DVD player.Some brand name DVD player,u must used it own DVD player remote to turn on the volume higer or lower to get it up or lower on the movie DVD discs or any kind of DVD discs are playing.The tv dosen't control the output volume of the movie,if the function require the DVD player remote to do it.Check ur DVD player remote see if u have a volume control buttons + - used those buttons on the DVD remote control u will control the volume of the movie DVD disc it is playing on the DVD player.
Aug 09, 2011 | Televison & Video
On able to use hdmi or usb inputs
HDMI and USB both run off the 5 volt power inside the TV. It is possible the 5 volt power is down in the set. Shop repair time.
HDMI connectors are frequently broken by allowing the wires to hang at the back of the TV. Most USB connections can only be used for MPEG movies and pictures. Check your owner's manual.
Mar 29, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have problems with my LCD HAIER TV. I put my USB and now i cant return to TV Mode. What i should do?
There should be a button on your remote that says "TV/USB". Try clicking it, that should take you to a blue screen that says No Signal, click Input, and you should be able to access your cable from the list of Input sources. This happened to me today, very annoying and unnecessarily confusing, especially since most buttons you press result in a screen that reads "Not Available." Urrgghhh.
Feb 12, 2010 | Haier HL42E LCD TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
