Duane Image Pro 8942 power light comes on for 5 seconds and shuts off
Posted by John Mullen on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,289 Answers
Probably a defective power supply
Posted on Aug 03, 2020
ASI Image Pro 2 Treadmill will not start
PLEASE see the video and proceed according. God bless you
Dec 10, 2013 | Exercise & Fitness
Dukane image pro 8942, black screen fades into
Before taking the unit in for repair, disconnect ALL video inputs. Make absolutely sure that on composite video, yellow goes to yellow, etc. BUT try the different video inputs one at a time( i.e. ONLY have the composite plugged in, or ONLY have the S-video plugged in) I ran into a situation with my own equipment trying to have more than one video source connected. I found that if, on a nice vhs player/recorder, I had multiple video outputs connected, the picture would become distorted. I ended up only being able to connect either S-video *or* composite video--it was almost like the video board was being "saturated" or bleeding over into other modes (for lack of a better description) That's why I want you to try the single output approach from the dvd player. The problem *might* not be with the projector--of course, if I'm wrong you're gonna have to have the projector repaired. Just trying to possibly save you some bucks here.---Rick
Sep 06, 2009 | Dukane IMAGEPRO 8942 Multimedia Projector
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Dukane image pro 8800 reset lamp timer
Reset Timer
1 Slide Cover on remote down
2 Hold timer button 5 seconds
3 Toggle to right - 0 CANCEL toggle back right to 0
Jun 11, 2008 | Dukane IMAGEPRO 8942 Multimedia Projector
Fujitsu Siemens AMILO Pro V2020
check if the power botton ve not shifted on the board and confirm if the system was properly shut down,but if the problem continues try and repair the operating system.
Thx
Feb 21, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
"spooling" when printing TurboCAD image
Spooling is a PC thing not printer Printer spool is an area of reserved memory which collects date for the printer before sending off - it seems it is not big enough to cope with the image size you are dealing with. check out the Computer route to adjust the spool memory size.
Jun 15, 2007 | Epson Stylus Photo RX500 Printer
Open Questions:
Samsung tv clicks and turns off and off in a cycle, you can see smart tv logo for a very small time before tv turns off again. Hey, so I have an issue with a Samsung tv un55ru7100fxza. It has this clicking sound and it’s in a cycle of turning off and on, you can see the startup logo for just a second before it turns off and on again. Almost every video I’ve seen so far talks about checking for bulging/ leaking capacitors but all the capacitors look fine and the solder joints on the back aren’t cracked or darkened. Next step is to take out each individual capacitor and test them which I really don’t want to do at all but I need to find the issue. I tried plugging in different boards to see if a particular board was causing it and I noticed that when I unplug the t con board the clicking stops and the tv stays on and I can manually turn it off, then I try and keep the t con board in and just unplug the 2 connectors that goes into the panel and the clicking continues, I feel like I need to replace the t con board but when I look up the symptoms of a t con board failing the tv just has fading or color distortions which I don’t have. So I’m kinda confused on why it would only click when that board is plugged in, if it was capacitor or power board issue wouldn’t the power board be clicking even if everything was unplugged? Awhile ago it’s done this but only for about 3 min then it worked fine and even for a week or two, but now it’s always doing it. I don’t know what to do since everyone I contacted wants hundreds of dollars to fix it. Is there anything else I can try?
Sep 22, 2020 | Samsung Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
