Question about Home
Pegasus 131-926 toilet not filling enough....how do you adjust this. The tank only fills up a little more than half, so it doesn't have enough water available for a complete flush.
Posted by HALLE ROCKCLIFFE on
Kardoc
    Top Expert:
  • 6,083 Answers
Posted on Aug 02, 2020
Where can I get a fill valve for Pegasus toilet
Use a fluid master universal fill valve, if it fits the tank. It will work as long as no part of the unit rests agains the side of the tank, if it does it will keep the float from rising.
Jul 03, 2014 | Pegasus Technologies Two-Piece Round...
CAN THE TOILET BOWL WATER LEVEL BE ADJUSTED?
Not sure on that toilet but you can fill a water bottle with the desired amount of water and then stick it in the tank thus tricking the toilet to put less water into the bowl with each flush. If you want more water though I am not sure how to do it.
Jun 11, 2011 | Pegasus Technologies Two-Piece Round...
How do I lower the level of the water in the tank so I do not use as much water per flush? I have a Pegasus 2 piece toilet thats about 2 years old
Hi there terminator,
Inside the tank, directly above where the water hose is attached, is the valve mechanism. Attached to this valve there is a float.
As the water level rises so does the float. When it get high enough, the float valve shuts off the water.
The idea is to lower the float so the water is turned off sooner.
If your model has a ball on a metal arm, it is as simple as bending the arm down a little bit.
Vertical cylinder types have adjustments on them.
Then there is the simplest solution which is to put a couple of bottles full of water in the tank to take up space. Therefore less water is needed to fill it...
Best regards
Mike
Mar 05, 2011 | Pegasus Technologies Two-Piece Round...
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
My pegasus won't flush with enough pressure to complete it...
Maybe the shut off valve is not open all the way .....
can you adjust the fill valve so that more water comes into the tank ... more water more flush !
Dec 07, 2009 | Pegasus Technologies Two-Piece Round...
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Jul 16, 2009 | Home
House of toilet noise
try bendind the brass rod down 1/4 inch in your stack
May 29, 2009 | Pegasus Technologies Two-Piece Round...
Home Logo
23 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
