What board needs to be replaced when horizontal lines appear on TV screen (Panasonic TC-P65ZT60)?
Posted by Scott Heikkila on
Arnie Burke
  • 6,480 Answers
Its cheapr to buy new at wal* cause ur tv is wearing out. Hav a littlfan in back for ur nex set...heat is what kill televisions
Posted on Aug 02, 2020
How to fix horizontal lines appearing on my Samsung TV
its a screen fault
if lucky and you can get one
one of the electronic boards inside the TV needs replacing
Mar 07, 2017 | Samsung Televison & Video
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Hitachi Plasma very thin bleeding horizontal lines
very possible the YSUS board is going bad .If YSUS is going bad .I would also replace XSUS board since they are same age..Also whenYSUS is replaced make sure you make pot ajdustments as old YSUS and also with XSUS board
Aug 26, 2009 | Televison & Video
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Oct 13, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Open Questions:
Samsung tv clicks and turns off and off in a cycle, you can see smart tv logo for a very small time before tv turns off again. Hey, so I have an issue with a Samsung tv un55ru7100fxza. It has this clicking sound and it’s in a cycle of turning off and on, you can see the startup logo for just a second before it turns off and on again. Almost every video I’ve seen so far talks about checking for bulging/ leaking capacitors but all the capacitors look fine and the solder joints on the back aren’t cracked or darkened. Next step is to take out each individual capacitor and test them which I really don’t want to do at all but I need to find the issue. I tried plugging in different boards to see if a particular board was causing it and I noticed that when I unplug the t con board the clicking stops and the tv stays on and I can manually turn it off, then I try and keep the t con board in and just unplug the 2 connectors that goes into the panel and the clicking continues, I feel like I need to replace the t con board but when I look up the symptoms of a t con board failing the tv just has fading or color distortions which I don’t have. So I’m kinda confused on why it would only click when that board is plugged in, if it was capacitor or power board issue wouldn’t the power board be clicking even if everything was unplugged? Awhile ago it’s done this but only for about 3 min then it worked fine and even for a week or two, but now it’s always doing it. I don’t know what to do since everyone I contacted wants hundreds of dollars to fix it. Is there anything else I can try?
Sep 22, 2020 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
