Question about Radio Communications
DW505 type 3: What is the resistance specification for armature opposing pole pairs? Also, isn't each pair supposed to be isolated from the other?
Posted by Sebastian Strauss on
Vernon Taylor
  • 6,823 Answers
Measuring across the commutator opposites is a rough check - if each pair has the same resistance it is probably good but even then there are no guarantees. I have never seen the armature resistance stated for any motor though that doesn't mean such figures don't exist.
It would seem logical that each pair should be isolated but that generally is not how the armature is wired and each commutator segment is the termination of two coils.
In reality there is only three ways to test an armature - either build it into a motor and see if it performs ok, use an automated motor fault analysis machine or one of the dedicated armature testers such as an armature growler.
Posted on Aug 01, 2020
What types of foods are best paired with Sparkling Wine?
Many people think that sparkling wines are best suited with sweet and decadent desserts. I go the other way, in fact, I find that the flavors are enhanced much more if paired with saltier foods. For specific pairing suggestions please visit the link below:
http://www.foodandwine.com/slideshows/champagne-pairings/1
Feb 03, 2013 | Wine & Spirits
Hi I have a 2001 Honda shadow ACE motorbike. There are 3 yellow wires going from the alternator to the voltage regulator through a 3 pronged plug. They have become very hot and fried themselves at...
3) there may be damage that has caused this
2)doesnt matter which yellow wire
1)maybe fried regulator or stator coils or aged insulation which has allowed a short between windings
The three wires are the 3 poles of the stator windings,
Fix the wires and plug first(electronics shops will have suitable 3 or 4 pin plugs to use)
get a multi meter and check resistance, any pair should have same resistance, non should short to ground.
with the bike running they will produce AC current (maybe 50-60vAC)again any pair.
If you are getting good AC voltace, then put the meter across the battery 12vDC engine stopped should rise to 14 vDC (about) when engine revved to 3000rpm
No AC -new stator
No DC-new regulator
Note voltages are estimates, many bikes run very similar charging systems
Jun 08, 2011 | 2001 Honda VT 750 CD Shadow A.C.E. Deluxe
The cooling fan comes on even when engine is cold and the engine stalls out on my 2001 Saturn l200
Would seem to indicate a faulty coolant sensor. If the sensor is mistakenly triggering the cooling radiator fan to come on then it most likely that it telling the ECU in error that the engine is at running temperature. When the engine is cold at start up the coolant sensor is supposed to inform the ECU of that fact. The ECU then sets a longer injection time to enrich the fuel/air mix to keep the engine running. As the engine warms the ECU responds to the coolant sensor signals by shortening and therefore leaning the fuel air mix. Your engine is stalling due to there not being enough fuel at idle at low temperatures. Check the connections to the sensor, they should be clean and free of corrosion (do not confuse the sensor with the temperature sender connected to the indicator on the dashboard; the sender has only one wire to the top of it). Check that there is continuity between the coolant pins. If it has four pins then the pair of pins diagonally opposed are on the same circuit. If there is a break (infinite resistance) then replace the sensor. You can check the sensor function by removing it and measuring its electrical response when its tip is put in hot water; generally the hotter it is the lower its resistance, with one pair of pins being about half the resistance of the other pair. As it cools the sensor increases its resistance. failure to see this indicates that a new sensor is required
May 09, 2011 | Saturn L-Series Cars & Trucks
Which Features I need to look for when purchasing a pair of tennis sunglasses?
Here are some important features: 1.Competivision is a term created by Bolle Eyewear, one of the best manufacturers of sports sunglasses. Competivision is the first lens technology created specifically for tennis. The concept behind this type of lens technology is simple muting all light except optic yellow allows the ball to pop out of the background so you can see it more clearly. This is a must-have feature for all tennis players. 2.Polycarbonate Lenses-Tennis sunglasses, like other types of sports sunglasses, require polycarbonate lenses for impact and scratch resistance. Tennis players need these types of lenses more for impact and shatter resistance than anything else. 3.Polarized Lenses-Polarized lenses are extremely important in most sports - tennis is no exception. This type of lens technology is important to reduce glare. Glare from the rackets, the net or the court can hinder your performance so its important to choose sunglasses with polarized lenses. 4.Tight-Fitting-You're going to want to choose a pair of sunglasses that fit snug to your face. A huge part of your performance as a tennis player is agility. You can't stop between every hit to stabilize your sunglasses or pick them up if theyve fallen off. You need a pair that's going to move with you, fitting tight and comfortably on your face.
5. UV Protection-UV protection is a very important element in any outdoor sport. It's not enough to simply have UV protection anymore, you have to make sure the sunglasses you choose provide 100 percent UVA, UVB and UVC protection.
esigner-sunglasses/oakley.aspx">Oakley is the original designer of specific sports-related sunglass models and the first company to release a line of sunglasses designed specifically for biking. Their tight-fitting, comfortable sunglasses have been worn by cyclists in the Tour de France. Highly effective but highly expensive, Oakley offers top-of-the-line sunglasses for sports enthusiasts.
Nov 07, 2010 | Clothing Accessories
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Brushes arc severly at point of contact with commutator. More than just brushes not seated. Comm. is round clean and looks good. Stator has been changed. Made no differance. Brushes are good.
If the brushes are long enough, severe arcing is often CAUSED BY FAILURE of one of the windings on the armature, NOT the stator.
Either an open or shorted winding will cause this. Use an ohmeter between adjacent segments to check the resistance. The resistance can vary by say, 10%, but if you find one pair that is outside that a bunch, look for broken wire near the commutator that you might repair, but beyond that, you usually have to replace the armature.
Sep 04, 2009 | Saws
Bearing Removal
hi
use a puller bearing.
regards savumihai71
Jun 20, 2009 | Dewalt DW505 Electric hammer drills
White euroflair 8910 motor won't turn on
motor inside the casing you have to remove the cover motor at the rear beside the handwheel of sewing machine loosen set screw or lift upside machine bed so you can see the motor and wiring circuit,if bottom cover is present loosen bolt remove cover you can check motor wiring using multitester setting to R10 set switch on and setting test probe red and black rod attaching the two terminal of male plug start pedal switch besure it was unplug on ac source if there resistance on the circuit and the motor.If negative result.Isolate checking the electrical circuit.check continuity of switch,if ok.check armature winding of the motor in two terminal of the motor, you have to pull out motor inside the casing first remove belt from the motor and handwheel.Loosen the 3 bolt from motor holder to the casing.In motor assymble unlock and pull out two carbon brush attaching tha armature brush replaced a new one pair of carbob brush and install back again.besure winding was not
burn out otherwise you to replaced the motor.
Mar 07, 2009 | Sewing Machines
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
