Question about Woods Hardware & Accessories
How to get my Woods dusk to dawn control to work on my two garage lights (one on the left and right of the garage door)?
Posted by Leon Daughrity on
john h
    Top Expert:
  • 23,504 Answers
Read instruction manual on your unknown model
Posted on Nov 23, 2020
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Outdoor halogen light does not shut off
some can be reset by removing power for a few minutes.
It would help to have the owners manual for the particular light because I have had some that went into different modes of operation by turning the switch off and on a prescribed amount of times
hope this helps
Posted on Jun 08, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: Describe your Intermatic K4221C Photo Cell Control
It may be your location for the photo cell. There is a cover on the cell in most cases that slides up and down to let in light. Or you may try turning it in a little different direction to get more light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Anonymous
  • 3 Answers
SOURCE: Dual Brite sensor lighting. Lights will not stay
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Posted on Jul 17, 2009
John Morganti
  • 864 Answers
SOURCE: I just bought a house with the Night Sentry EJ351
Here are the instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
You will have to pick the times you want the lights to go on and off.
Posted on Oct 29, 2009
Anonymous
  • 27 Answers
SOURCE: Need wiring diagram for installing a photoelectric
I am reasonably sure the black wire connects to the black/hot power wire coming in, and the red continues on to the light. I am positive the white wire is connected to all the other white wires. The white wires usually do not connect anywhere on the device, just wire nutted together in the box
Posted on Nov 03, 2009
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 02, 2012 | GE Home
WOODS TIMER - Woods 17321 Dusk-to-Dawn 3 plug yard stake timer
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
These household-type timers have 1 year limited warranty. Sometimes they last for a few months, or stop after 1 year, and occasionally they last longer 3-4 years.
Solution:
Buy another yard stake, or plug-in timer:
Example in-wall timer: Woods 49650-59204 at my house.
http://waterheatertimer.org/images/IMG_2060-woods-59204.jpg
Another handy thing is the Woods 32555 remote control. Let's you turn on outdoor lights from inside the car, or inside the home.
http://waterheatertimer.org/images/Woods-3255-image-500.jpg
Each item above is sold at Amazon, or local home center or hardware, or box store Sears-Target-etc
Nov 19, 2012 | Hardware & Accessories
It works fine until the time i have set for lights to come on they dont come on, but if i plug in recept. Ii works fine
Timer is not identified. Problem is not clear.
Add a comment with clear description of product, and say what you have done to set timer.
What do you plug-in to make lights work?
Question is posted under Woods dawn-dusk timer that turns ON automatically at dusk, and then turns OFF 2 4 6 or 8 hours later:
Many different timer-brands work in same manner.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Jul 28, 2011 | Woods Outdoor Lighting Timer
Woods vacation villa 2 room tent manual needed..Please help
Woods 83660 security timer appears to be same/similar as Coleman 2001/Woods 49647
Instructions: Timer turns ON automatically at dusk
Use dial to set 4 possible options:
Off = always OFF; ON - always ON
Dusk-Dawn = ON at dusk, OFF at dawn
2,4,6,8 hours = ON at dusk, lights OFF 2,4,6,8 hours later
Woods Model 2001-49647 manual
Jul 10, 2011 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
How do you set the timer
You posted under Woods outdoor timer:
See this timer and other similar types to identify your timer for sure
If this is not your timer, look at other timers on the page and then add a comment, and I will post instructions for another timer.
Generally this type of timer each set the same way:
Instructions:
Timer tuns ON automatically at dusk
Set dial to Off , the timer is always OFF
Set dial to ON, the timer is always ON
Set dial to Dusk-Dawn, the timer is ON at dusk, OFF at dawn
Set dial to 2,4,6,8 hours, the timer is ON at dusk, lights OFF 2,4,6,8 hours later
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | Woods Outdoor Lighting Timer
I want to use just the pm of the timer....for xmas lights....I see how the arrowis to be put on the 5 .....thats when i want them to come on....and 9 later in the evening....where do i put the arrow for...
You posted under The Woods/Coleman 2001 timer.
This is same as Westek TM14DOLB, Sylvania SA200 and similar to GE 57696.
If this is not your timer, add a comment with description and brand of timer.
Also see Woods timers and manuals to help identify your timer.
This particular timer turns ON automatically at dusk.
And then you set the dial for other options as follows.
Dial set to ON > timer ON full time
Dial set to OFF > timer OFF
Dial set to 2 4 6 8 > timer turns OFF 2 4 6 8 hours after dusk
Dial set to Dawn-dusk > timer turns OFF at dawn.
Dec 12, 2010 | Woods Outdoor Lighting Timer
Need instructions to set this timer
You posted under a photo that looks like Woods/Coleman cable 2001/49647 timer
See image at Amazon
http://www.amazon.com/dp/B00002NB2X/ref=asc
If this is not your timer, see all Woods timers and manuals at following link:
Add a comment any time
Manual for Woods 2001-49647
http://waterheatertimer.org/pdf/Woods-2001-49647.pdf
Instructions:
Plug in timer, plug lights into timer, capacity 1875 watts
50-mini-bulb string of Christmas lights is 25 watts
Off = always OFF
ON - always ON
Dec 09, 2010 | Woods Outdoor Lighting Timer
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Hardware & Accessories Logo
Top Woods Hardware & Accessories Experts
Gene Haynes
jdthefixer
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
