How do I set up my JND-3308RK video recorder system?
Posted by tiffany kalino on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,309 Answers
Set it up in accordance with the instructions you receive from the manufacturer/distributor in response to your request.
Posted on Aug 27, 2020
How to record music on youtube
After downloading, install and launch the program.
On the main interface, click gear icon and select "Settings" from the menu. In the pop-up window, set the input audio source as "System sound".
Play the YouTube video, back to the recorder interface and click red record button.
While you record YouTube audio online, the software will identify the music info.
Hit "Stop" to end recording, then the recorded audio goes to the target folder.
go this link to download
https://www.apowersoft.com/record-audio-from-youtube.html
Jun 12, 2017 | YouTube Computers & Internet
Why is the red square always flashing on the display go video model ddv-d550?
That would be the timer record indicator. It has either a setting that has not completed (due to a transmission error) or you have set something by mistake to record something on a daily basis and is waiting to be shut down or have something to record on inserted.
Clearing the record screen should clear this. If it doesn't then is a system fault. If this uses a tape, the mode switch will be faulty.
Jan 20, 2016 | Rio Go Video DDV9556 Dual Deck VCR
Get the unit to turn on my recorder for recording what the camera see's
You are likely asking a question about recording "Motion Detection", yes?
Ron, this option is most likely to be accessed in the Setup menu of your system. Please know, a motion trigger is not without some drawbacks, mainly: it can miss some "action" to begin with.
If you have a good-sized Hard Disk Drive in your recorder, just set it to record always, and to record over the old stuff when it gets full. I have a "mid-sized" 500 GB HDD, strapped to 14 cameras, and it is good to go for about two weeks worth of recording every camera.
It is very likely that specific questions - like this one - can be answered by the manufacturer of your system, online, and "live", through an online "Chat" service. Surveillance Cameras are a hot item, and service is the name of the game, so most manufacturers have a live chat 24/7
Plug in the name of your system to Google, look for the website, and check it out. If your system is NOT "on the list", go to a website that has a system that just "looks" like yours, and lie to the chat person about it. Download a copy of the instruction manual, too. Print it out and set it near the recorder, for future reference.
Play with and practice with your system. Be sure you know how to easily "rewind" the video, and be able to show the police what you have captured and recorded if need be. Practice loading up a selected video to a flash USB drive for them, too. Keep a $5 one plugged into the unit for just that purpose. PRACTICE! Remember that ONE WRONG CLICK and you will forever lose the video! Do NOT play with it when you are excited or in a hurry, or you will surely goof it up, man.
Good luck, Ron!
Mar 07, 2015 | Home Security
Is my Magnavox 1T HDD rECORDER COMPABILE WITH cOMCAST cable Box ?
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: http://funaiport.com/upload/MAGNAVOX/Manual/MDR537H_EN_OM.pdf . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: http://customer.comcast.com/help-and-support/cable-tv/cable-box-user-manuals/ )
Sep 25, 2014 | Televison & Video
HOW DO I GET MOTION DETECTION TO WORK?
Are you sure the cameras are capable of motion sensing and make sure that you do not need an additional control cable to the camera to make that work.
Jul 17, 2014 | First Alert Home Security
On video call i can hear and see my correspt, he can see me but can't hear me. checked all sound settings, ok. is it a driver problem?
no its not a driver problem
this happens when either the operating system or the video call software doesnt have the correct device selected in the recorder section
check if both the operating system and the video call software have selected your voice recording device
Sep 29, 2009 | ASUS P5VDC-MX Motherboard
Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
May 19, 2009 | Panasonic DMR-ES10 DVD Recorder
I have a pc running geovision 250 and was wandering where to look for the video recordings
The recording are saved in c:\gv250 if you have just C driver and then you browse to folder for specific recording. If you have multiple hard drive you can check from Geovision Main system software setting to figure out here the recording are stored. Easy way to do that is stop all monitoring in main systems and then press F9 for systems configuration and go to storage settting. There you will see path for saved recording.
You can also view your previous recording right from GV main screen by just pressing F10 key and then select the date and time you wanna watch recording for.
Thanks
Apr 13, 2009 | Geovision GC-250-2 (gv-250-2) Video...
Video recording
Hi
open the camera shutter select the video recording >click on settings > click on shoot mode > select High Quality Video nad now you can shoot unlimited video
Sep 03, 2007 | Sony Ericsson W700i Cellular Phone
Capturing video & audio through s-video input .
Hi, try this, go to control panel-click sound and audio devices and ensure that your system is configured to the right devices for recording from your camera. The easiest way to run any of this equipment is to set all systems at default. and purchase a USB sound/video adaptor [cheap from china] and plug your camera into this when you wish to record from it. when finished, remove the adaptor the same as you would with any USB hot swap device, your computer will revert to the default settings. Next time you use your camera , plug it in and windows will auto detect it again. Goodluck. mistyman
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
