Tcl dim screen - Televison & Video
Posted by Maxime Desrochers on
Anon
  • 1,437 Answers
If the picture mode is set to Cinema or Custom, the screen could become dark. If the screen is still dark after the picture quality mode has been changed, change the setting Backlight, Picture, Brightness and adjust the brightness to your taste. ... Depending on such settings, the picture brightness level can be higher or lower
Posted on Jul 29, 2020
Need to speak to a tech support person Now please
We are FIXYA, we ARE NOT TCL. Contact them direct by phone.
Apr 14, 2018 | Televison & Video
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 30, 2017 | Televison & Video
My TCL LCD TV STL308B330 Power is on and Screen is blank with dimmed light blue but sound is ok
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Televison & Video
Tcl tv model no dn2127h sound ok but no display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Televison & Video
Tcl tv screen
T'Con board is faulty. Should be replaced.
Apr 30, 2013 | TCL L32D20
Wont turn on
Do you have or get sound or is it total off?
Nov 05, 2012 | Target TCL 32" Class 720p 60Hz Edge Lit...
Problem with TCL Television
I have also a problem regarding the TCL-2027 the trouble is half screen.I replace the vertical IC together with all neighbor capacitor but same problem unsolve.so please help me asap.and what
is the service mood of TCL-2027.just send your help at [email protected].
Jul 01, 2008 | TC Electronic Computers & Internet
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
