Gilson has been out of business for years. you might get lucky here
https://www.google.com/search?q=1985+Gilson+Bros.+model+%23+51183+rear+tine+tiller&rlz=1C1CHBF_enUS757US757&oq=1985+Gilson+Bros.+model+%23+51183+rear+tine+tiller&aqs=chrome..69i57.679j0j4&sourceid=chrome&ie=UTF-8
dayco belts are L346 Trac Belt L446 Tine Belt
Contact Gilson directly to inquire.
SOURCE: I have a Gilson Bros. Rear Tine Tiller. I need
check and if the end off axle has a swelled place use a file or sand paper to smooth it out.try some penetrating oil that will help
SOURCE: need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
SOURCE: gilson roto tiller model 51082
You should be able to turn the tines. Check them by hand, sounds like a bearing is frozen.
Testimonial: "i tryed to turn by hand it wont turn its done this before and i let it sit for a bit and it started to work again but this time i just dont know"
