Question about Rowenta Irons
Taking apart the rowenta industrial steamer to fix the switch
Posted by Patricia Hann on
Tom Chichester
    Top Expert:
  • Rowenta Master
  • 57,442 Answers
Contact Rowenta to request an assembly diagram, then follow it in reverse.
Posted on Jul 29, 2020
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
Aug 13, 2014 | Rowenta Commercial Garment Steamer - White
Were can i take my rowenta steamer for repair in the 90035 los angeles area
Anaheim, Berkley, Fresno, Bakersfield, Los Angeles,
Long Beach, Sacramento, San Diego, San Jose and San Francisco.
Google Rowenta repair Center, choose a city and go!
Jul 24, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
On off light never shuts off
Clarification: When you "switch off" the unit, does the light stay on, but the steamer itself shut off (cools off to no steam)? If this is the case, only the LED does not light (which will not affect actual performance, other than being a "false" indicator driving some users crazy) like an Engine light that stays on in your car. It is likely a bad connection rather than a bad LED (Light Emitting Diode indicator). If the steamer portion is powered on all the time regardless of the switch position, try turning the temperature settings all the way down on the base and iron before unplugging unit to prevent the arcing (sparks) from damaging the input AC plug.
Solution: you will need a small Security Torx Bit/Driver to take unit far enough apart to inspect, troubleshoot and determine cause. You will also need an analog or digital multi-meter to check the unplugged unit' switch using self-powered ohm-out (continuity check) function, testing forward & reverse diode for lo & hi resistance reading respectively, (if you use the Rx1 range, the diode will glow slightly in one direction if it is good & you use an old analog meter). If you are so inclined or know somebody into electronics to do this, you can get these tools at Harbor Freight for $10-$20, good luck and keep in touch.
Apr 26, 2008 | Rowenta DG5030 Iron
Irons Logo
27 people viewed this question
Top Rowenta Irons Experts
Bruce Showalter
Colin Stickland
Colin Stickland
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
