Question about Whirlpool Home
Can I plug up the neck jets in my Koehler whirlpool without damaging the other jets?
Posted by Susan Schwartz on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Whirlpool Master
  • 36,337 Answers
Probably since its not a positive displacement pump. expect more pressure from the other jets though
Posted on Jul 29, 2020
I have a Jacuzzi brand bathtub/whirlpool 6 years old. One of my jets leaked and created a significant damage downstairs. How can I fix the jet, how can I prevent other jets from leaking? Can I just kill...
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Sep 12, 2010 | Jacuzzi Home
Kohler Whirlpool K-1266 (Does not star
Here are some possible causes and solutions. I know some seem simple but am trying to cover all base
  1. Jets Closed, rotate Jet trm ring counterclockwise to open.
  2. Jet not installed correctly, re-install jet, check for 'O' ring damage.
  3. Jets are blocked, Check for blockage and remove.
  4. Pump is not priming, Pumps with wooden support blocks only, Pump shimmed to high, lower pump support bracket. (wooden support blocks only)
  5. Pump is air locked. Loosen fitting on pump outlet to allow any air to escape, re-tighten.
  6. Air Actuator tubing is disconnected, loose, kinked, plugged or damaged. Connect, straighten, clean or replace air actuator tubing.
  7. Air Actuator does not work, replace the air actuator
visual check to see if pump is turning when motor is is on. If not replace the the pump you may need to disconnect the the inlet/outlet to see. I hope this helps at least provide some direction. Good Luck, Jeff
Apr 05, 2010 | Kohler Home
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Mar 04, 2009 | Home
Whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Home Logo
21 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
