Question about Maytag Refrigerators
Freezer model mqf1656tew02. Why isn't it getting cold?
It turns on, lights and all but doesn't keep things cold.
Posted by Christopher Tiong on
setuphpprinter123hpcom
The Process for HP Printer installation is quite easy and important to complete on purchasing a new HP Printer to do printing tasks. However, if you are new to HP printers then you might got questions in regard to completing HP Printer installation. There is nothing to get worry about as in this post you will grab the right steps to complete HP Printer installation. The primary tasks you have to do is ensure that HP Printer drivers package is download and install properly.
Posted on Nov 21, 2020
ray gallant
    Top Expert:
  • Maytag Master
  • 70,853 Answers
Probably needs freon added and you need a tech for that
5 Related Answers
Anonymous
  • 237 Answers
SOURCE: High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Posted on Jan 13, 2007
Anonymous
  • 62 Answers
SOURCE: Fridge not keeping cold
check the controls and make sure they are set properly, so that you are getting air into the ref. also a common thing is that the evap fan motor could be bad and not blowing air into the ref area. it could also be the start of a defrost problem
Posted on Sep 06, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Posted on Dec 25, 2008
Anonymous
SOURCE: zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Posted on Mar 28, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Posted on Sep 30, 2010
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
I have a Maytag refrigerator with above freezer. Model # MTB1956AEB. All of a sudden, the freezer doesn't keep the food frozen. It still works, icecubes are frozen, but icecream is very soft, as if the...
It sounds like your defrost assembly has ceased to function and you have ice build up on the thermostat telling the freezer it is cold enough. Pull power. Take the food out of the freezer, remove shelves and bins, remove inside back cover. IF there is a lot of ice build up behind it then you can either leave the door open so that it will defrost or use a hair dryer to speed the process up.
Once the ice is cleared out, you can plug it up and see if things start working again. At least the freezing and getting cold part. If this worked then you will need to order the defrost assembly using the information from the information plate inside your refrigerator, then install it.
Jun 04, 2011 | Maytag Refrigerators
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Jul 11, 2008 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
