Rockola 460 speakers humm and light says speaker overload
Posted by Ron Kephart on
Tom Chichester
    Top Expert:
  • Audio Player... Master
  • 57,285 Answers
The speakers may be burned out.
Posted on Jul 27, 2020
Volume reduced to half on my rockola 454 jukebox.speaker overload lamp is lit.
Sounds like it's drawing too many amps.
How is it hooked up?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 06, 2016 | Audio Players & Recorders
Rockola 481 max 2, mechanical overload light comes on, reset button resores play for a short time, what causes it?
Sometimes a motor is too slow because it's dirty and more current is needed to turn it, so everything ramps up and overloads.
Nov 11, 2014 | Audio Players & Recorders
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
NO HAY AUDIO
Lights? No?
Check power cables.
Any sound at all (click, hum)? yes?
Check audio cables.
Any sound at all (click, hum)? No?
Check speaker cables.
Check speakers.
Is head unit sending audio?
Try connecting direct to speakers. Working? Amp has fault.
Not working? Head unit has fault or is wrongly wired to amp.
Sep 02, 2011 | Dual XAF-460 Car Audio Amplifier
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Jan 06, 2008 | RCA RT2600 System
32 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
