Question about Cell Phones
Why does my Cellphone keep on freezing on me ?
Posted by Tammy Smith on
Anon
  • 1,354 Answers
If your iPhone suddenly freezes or keeps on freezing on you or refuses to wake from sleep, you can sometimes fix that issue by restarting it Or turning it off and then turning it back on. If this doesn't resolve the issue, or you cannot power on your fully charged iPhone, try resetting the device. Simultaneously press and hold the "Sleep/Wake" and "Home" buttons for at least 10 seconds.
Posted on Jul 25, 2020
Try open inbox freezes
Go into settings, then manage apps, go in and clear your caches on each downloaded app 1st. Then go into your playstore and find a cache cleaner/memory boost. This should help remind you to keep them cleared up and it will stop freezing and run faster.
Jan 30, 2014 | Nokia Cell Phones
My phone keeps freezing up and going slow
hi,
this mainly of using over memory or virus attack scan the cell for virus..... or format your cellphone...
thanking u
Jan 10, 2011 | LG Cell Phones
Calendar on phone is good, calendar on computer is gone I tried hot sync with just the calendar only, but that freezes. what should I do
1.Bought Palm centro with freezing up problem then returned and got another one.
2. Second Palm centro again with freezing up with additional screen flickering problem....buy one problem take another problem....good huh? buy one take one..
3. Third Palm centro after returning the second, now I stil have and inherited the freezing up problem .....you always inherit the freezing up problem even as many times as you changed your PALM CENTRO.
conclusion:
I WILL NEVER BUY PALM CELLPHONE AGAIN.
Jun 15, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Why in on the cellphone is freeze
i think you enter a wrong code for almost 5 times or more..it will fix with z3x samsung box..go to cellphone shop near you and they will un-freeze it by using z3x samsung box...
May 20, 2010 | Samsung SGH-t819 Cellular Phone
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
My nokia n95 8gb keeps freezig . Why how can i fix i without leaving it into repair shop
If you want not leave your phone into a repair then this solution can really help you. What I want you to do in your cellphone is to deep reset it. Deep resetting your phone can clear all the mess inside your phone that causing the phone to freeze. To do this just simply dial this number, *#7370# and it will ask restore all original phone settings, press okay to restart and it will ask a code which the default is 12345. The phone restart and will restore your cellphone. Hope this could help you. Pleas don't forget to rate this solution. Good luck.:-)
Oct 26, 2009 | Nokia N95 Cellular Phone
Tmobile shadow cellphone
Power the Shadow off. Hold down the two soft buttons (The two right under the screen) and turn it back on. There should be a quick menu that pops up asking if you want to reset it. Say yes, let it reboot, and it will then start restoring your phone to defaults.
You will loose all your data.
Jun 21, 2008 | HTC Shadow Smartphone
The phone keeps going blank. So I have to turn it back on and then it freezes. it will not work at all.
consult it to a cellphone technician bec. ur phone needs to be flashed your flash program is corrupted.
Mar 12, 2008 | Cell Phones
Cellphone freeze
one thing to do is loosen the screw on front screen near the volume buttons..remove the small rubber circles first so you can see the screw..
Nov 07, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
78 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
