Question about Vizio Televison & Video
Have picture and sound then picture starts blacking out but still has sound . Have a Vizio E552VL model When turning on hooked to my cable everything works for a few minites picture and sound then the picture flickers and goes away there is some elumination to the picture but never comes back still has Ssound . Power board ? Led board? Which one should I replace? Have the back off no visible damage that is obvious to the boards . When left pluged in and then turned on vizio logo would freeze when turned on and I would have to do a hard reset . Unpluging and holding on button for 30 seconds and pluging in again That would allowit to get past the frozen Vizio logo and allow the picture to come on full function great picture . After a 5 or 10 minute time frame sometimes longer maybe 30 minites picture would start fading out with horizontal interuption then go black with sound still on . Have a new power board ordered . Any advise appreciated. Thanks
Posted by jerome kozlowski on
  • jerome kozlowski
    jerome kozlowski Jul 25, 2020
    Replaced power supply board . Still doing the same thing . After turning on and 10 mins or less of viewing picture starts getting horizontal lines and then fades out to no picture but sound is fine .
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: Screen powers off and power indicator goes out after ~30 minutes
Your message is pretty old but I'll give you my un-copywrited spiel anyhow;
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 25, 2008
deltonsmith9
Delton Smith
  • 96 Answers
SOURCE: Vizio 32" Froze, then no more picture or sound
how long did you leave it unpluged
Posted on Jun 04, 2012
Derrick Gee
  • 3 Answers
SOURCE: Vizio E550i-b2 TV has no backlight, pic or sound. Replaced power and Main boards - still having the problem. Any suggestions? I have the TCON and LED Driver board left
The led is what makes the picture try replacing that it it's the only one you didn't change out
Posted on Aug 31, 2016
Lawrence Oravetz
  • 10548 Answers
SOURCE: Power Shutting Off on Vizio D50U-D1
Start with the power supply board first. That usually fixes the problem. No need tor the T-con board.
Posted on Aug 09, 2017
Larry
  • 2800 Answers
SOURCE: vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Posted on Feb 09, 2018
Testimonial: "I have 3.5 volts and 5 volts nothing else."
I have a Vizio E552VL and it works great except it has this annoying buzzing sound coming from the back all the time!
TV power board has problem,you can replace the power board ,and try again.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
Aug 22, 2018 | Vizio Televison & Video
Hi, I have a Vizio model number E552VL. I have had it a little over 2 years and the picture is getting a little dim and less sharp. Do need the backlight inverter kit to fix it? Thanks
I am not familiar with that kit, have you tried to compensate with the picture controls as much as possible?
I found this link:
Replace LCD Backlight Inverter on Any Monitor for
I wouldn't take preemptive action unless it got pretty bad. Here is a video that may have some applicbility.
Jan 02, 2015 | Vizio 55" E552vl Wifi Internet Apps 1080p...
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
My 42in Vizio LCD has sound but no picture. Screen starts blue when it turns on then goes to black with only sound.
Make sure in the back of the TV the "picture cords" or A/V cables are properly fitted.... Hope this helps :)
Jan 08, 2011 | Vizio 42 in. LCD TV
Vizio 50" Plasma HD
just purchased 2/7/08 Model # VIZIO JV50P HDTV 10A followed instructions to install cables but when turned not allowing me to do initial set up. Can't access menu from remote either PLEASE ADVISE. ....MO
Jan 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Blue screen, no picture
Sounds like you switch the tv from pal to ntc or around.
Dec 07, 2007 | Vizio L37 Television
Televison & Video Logo
83 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
